Post Info TOPIC: Non stick..
Non stick..
May be an image of text that says "Non-stick Fry Pan 25cm"
These lables attached to products are an absolute pain in the backside. Every new electrical appliance has conspicuous lables advising energy capabilities - too late once the product is delivered into the home.
Hi all; My wife saves jars and reuseing them for when she make jams and chutney. Trying to get the labels off of these takes some doing. Hot water and a knife will get the lable off, but the glue that is used need a soak in eucalyptus oil and even then some glue is left. Time to head out to the man cave and try a bit of acatone. This works for what is left and then another wash in hot water for a final clean up of the jar.
I don't know what type of glue is used, but does NASA know of this stuff, it could come in handy for sticking the tiles back on the space shuttle !!!
-- Edited by valiant81 on Thursday 16th of November 2023 09:53:04 AM
Try a product called adhesive remover, made by 3M you can get it at any automotive or marine paint shop cheers.
Spraying the labels with WD40 works on some labels, let it soak in a bit and then scrape the label off. Good luck.
Sometimes putting the glass in the freezer will make the glue brittle & it will chip off & scrape off more easily.
Don't put the glass in hot water or it will most likely crack from the cold temperature.
Never found glue residue that wont wash off with a bit of petrol on a rag. Quick, simple and product generally available in man cave. Rewash in hot soapy water after.
Only problem is the cost.biggrin
-- Edited by Sarco Harris on Tuesday 21st of November 2023 09:38:36 PM
Mineral Turps Is also good for getting that sticky goo off.
Blues man.
Wrote Blues and Sarco.
Ah sounds good, " painters and drag racers" snags.
Cheers Craig
in the same box as child proof locks, they beat me every time
