Post Info TOPIC: Girard has hot water system won’t ignite
Hi all, on the road camped up at Burra in SA The gas hot water system (Girard) was working fine last night but today is displaying E1 error code Plenty of gas in the gas bottle Would appreciate advice Thanks
 Hi Jarrah,
This is the link to the error codes but it could be a number of issues causing it.
https://www.girardendlessho****er.com.au/troubleshooting
Your manual too if you don't have one.
https://www.girardendlessho****er.com.au/_files/ugd/4f1865_76706129c55d496299bda1a673f7de18.pdf
If you have gas in the bottle it could possibly be the regulator or an air lock but first you need to check if there is an ignition spark.  Light your stove for a while to check that gas is flowing there as this will indicate if your regulator has issues his and may also remove any airlock.  If you do see an ignition spark I would wait a few minutes before attempts so that if it is an airlock at the water heater you will be gradually releasing the air.  Good luck.
Tim
lol the links changed because there there is banned word in the middle and it put in four asterisks when posting so replace them with 't w a t'
 Tim
-- Edited by TimTim on Sunday 2nd of August 2026 11:41:52 PM
G'day Jarrah,
I had a Girrard Continuous fitted in my aluminium tent when built. The place I had it built tried hard to talk me out of it but NO. I'm paying so do it.
OOOPS
After two years of not even warm water and three trips to agent to get it looked at, still no hot water. I was very annoyed.
SO
I bit the bullet and had a Suburban gas/electric hot water heater fitted, it went in the same opening and I have enjoyed hot water ever since.
IF ONLY I HAD LISTENED
RE: hot water system diesel
Good to hear you got hot water My diesel hot water system is going in for a tweak at the caravan repairer this week The strategy is to insert a water flow destructor into the cold water line as it enters the heating component .. Will let you how it goes , have started praying to the god of hot water .
RE:
The Gas/electric in my Truma almost gives me a full shower before going cold. Is there any way to improve it?
Don't forget Matilda
Check these...
Have you got the cover off the external exhaust?
Have you got at least 12v-13v to the unit?
Is the thermostat set to highest temp and higher than ambient temp?
Is the gas flow ok, eg, stove burners nice blue colour without yellow tails?
Have you tried lower water pressure, about half setting on sink tap?
Have you disconnected battery power to heater for 10mins then reconnected and tried again?
-- Edited by Dick0 on Sunday 15th of November 2026 03:42:33 PM
Cheers, Richard (Dick0)
Dick0 wrote:
Check these...
 Whoops... on the wrong track, sorry.
Here's one way to defeat the stupid profanity filter:
https://www.girardendlesshotw%61ter.com.au/troubleshooting
https://www.girardendlesshotw%61ter.com.au/_files/ugd/4f1865_76706129c55d496299bda1a673f7de18.pdf
-- Edited by dorian on Wednesday 18th of November 2026 01:11:46 PM
Which Girard model is the problem product?
