Post Info TOPIC: Girard has hot water system won’t ignite
Hi all, on the road camped up at Burra in SA The gas hot water system (Girard) was working fine last night but today is displaying E1 error code Plenty of gas in the gas bottle Would appreciate advice Thanks
 Hi Jarrah,
This is the link to the error codes but it could be a number of issues causing it.
https://www.girardendlessho****er.com.au/troubleshooting
Your manual too if you don't have one.
https://www.girardendlessho****er.com.au/_files/ugd/4f1865_76706129c55d496299bda1a673f7de18.pdf
If you have gas in the bottle it could possibly be the regulator or an air lock but first you need to check if there is an ignition spark.  Light your stove for a while to check that gas is flowing there as this will indicate if your regulator has issues his and may also remove any airlock.  If you do see an ignition spark I would wait a few minutes before attempts so that if it is an airlock at the water heater you will be gradually releasing the air.  Good luck.
Tim
lol the links changed because there there is banned word in the middle and it put in four asterisks when posting so replace them with 't w a t'
 Tim
-- Edited by TimTim on Sunday 2nd of August 2026 11:41:52 PM
G'day Jarrah,
I had a Girrard Continuous fitted in my aluminium tent when built. The place I had it built tried hard to talk me out of it but NO. I'm paying so do it.
OOOPS
After two years of not even warm water and three trips to agent to get it looked at, still no hot water. I was very annoyed.
SO
I bit the bullet and had a Suburban gas/electric hot water heater fitted, it went in the same opening and I have enjoyed hot water ever since.
IF ONLY I HAD LISTENED
