Post Info TOPIC: RV Driver Empties Waste Tank Into Colorado Gas Station's Diesel Supply
RV Driver Empties Waste Tank Into Colorado Gas Station's Diesel Supply:
https://cowboystatedaily.com/2026/05/27/rv-driver-empties-waste-tank-into-colorado-gas-stations-diesel-supply/
"The Maverik gas station in Montrose, Colorado, can't sell any diesel after someone dumped an RV's waste tank into the station's underground diesel supply."
Not sure why this is in the jokes section, if true then is a very expensive and inconvenient mistake. If it's made up I fail to see the humour.
https://quoteinvestigator.com/2026/01/24/comedy-manhole/
Interviewer (Carl Reiner):
How do you differentiate between tragedy and comedy?
2000-Year-Old Man (Mel Brooks):
To me, tragedy is if Ill cut my finger. Thats tragedy. It bleeds, and Ill cry, and Ill run around, and Ill go into Mount Sinai for a day and a half. Im very nervous about it. And to me, comedy is if you walk into an open sewer and die. What do I care? Thats comedy. My finger is important.
Don't forget Matilda
Dark humour perhaps?
Cheers, Richard (Dick0)
Toilet humour?
If it is true then I would think that they would have the culprit on camera. It doesn't matter what system you have, if you see a risk for human stuffup and think that "nobody would ever be silly enough to do that" someone will eventually come along and prove you wrong..
