Post Info TOPIC: Mind boggled newbie ford ranger v Toyota hilux
Im a newbie.  Im just starting out trying to put a rig together.  I recently saw a ford ranger which seemed like a good deal. It has a 3.2 turbo diesel with 264000 klm. I see a lot of negative info online about these. I liked it because it has had the GVM upgrade and all wet to go with a jayco sportstar slide on   Anyone got anything positive to say about a ford ranger 3.2 turbio diesel.   Also what i the best way to connect a slide on to your Ute?    My current t Ute Toyota hilux D4D needs upgrade and some form of hardware to attach to chassis   Any advice would be most welcome
We owned a slide-on for a few years. Bad idea.
Heavier than an equivalent motorhome, much higher CofG with water tanks above the chassis instead of below, too hard to take off and put on.
I strongly advise against slide-ons unless they are seriously light weight and top of the market versions, then you might as well buy a motorhome.
And a dual cab would be the absolute worst choice of vehicle because the weight is much too far back and the rear axle is likely to be overloaded.
Be very careful.
-- Edited by Peter_n_Margaret on Sunday 21st of September 2025 06:29:11 PM
