Post Info TOPIC: One of my favourites
Pilots Vs Maintenance Engineers
After every flight, pilots fill out a form, called a gripe sheet which tells mechanics about problems with the aircraft. The mechanics correct the problems; document their repairs on the form, and then pilots review the gripe sheets before the next flight.
Never let it be said that ground crews lack a sense of humor. Here are some actual maintenance complaints submitted by pilots (marked with a P) and the solutions recorded (marked with an S) by maintenance engineers.
P: Mouse in co.ckpit.
S: Cat installed.
P: Left inside main tire almost needs replacement.
S: Almost replaced left inside main tire.
P: Test flight OK, except auto-land very rough.
S: Auto-land not installed on this aircraft.
P: Something loose in co.ckpit.
S: Something tightened in co.ckpit.
P: Dead bugs on windshield.
S: Live bugs on back-order.
P: Autopilot in altitude-hold mode produces a 200 feet per minute descent.
S: Cannot reproduce the problem on the ground.
P: Evidence of leak on right main landing gear.
S: Evidence removed.
P: #2 Propeller seeping prop fluid
S: #2 Propeller seepage normal #1 #3 and #4 propellers lack normal seepage
P: DME volume unbelievably loud.
S: DME volume set to a more believable level.
P: Friction locks cause throttle levers to stick.
S: Thats what theyre for
P: IFF inoperative.
S: IFF always inoperative in OFF mode.
P: Suspected crack in windshield.
S: Suspect youre right.
P: Number 3 engine missing.
S: Engine found on right wing after brief search.
P: Aircraft handles funny.
S: Aircraft warned to straighten up, fly right, and be serious.
P: Target radar hums.
S: Reprogrammed target radar with lyrics
P: Noise coming from under instrument panel. Sounds like a midget pounding on something with a hammer.
S: Took hammer away from midget
-- Edited by Mike Harding on Friday 21st of April 2023 01:54:39 PM
