Post Info TOPIC: Solar panel angle
Solar panel angle
I'm currently camped at around latitude 34d south and decided, it being 2nd May, to change the angle of my solar panels to their winter setting; or from about 45d to 60d. Doing so has increased panel output by about 11% as determined from an 11am test. When I made the legs for these 4 x 200W panels I calculated a set of angles for Australia and drilled multiple holes in the legs to suit so changing the angle is a simple task and a worthwhile one too it seems.
Hmm Mike good to know you still work to the callender even in the bushhmm That is a good boost.
Yes it is simple to do an uncomplicated stand that just works (without a motor. Gees where do you switch it on sir) confuse
In Norway, especially north of the Arctic Circle, they stand solar panels verticle.
The added bonus is that the snow does not build up.
Can this website be used with confidence?
https://solarcalculator.com.au/solar-panel-angle/
Don't know about the above, this is the one I use:
Solar panel angles
Ensure you understand which of the two angles are being referred to.
Solar panel angles
 Two angles???
Just have the panel at right angles to the direction of the sun. That's the big bright thing up in the sky. :)
Solar panel angles
 Two angles???
Generally the panel will form the hypotenuse of a right angled triangle thus if I say place the panel at 60d I could be referring to either of the two angels which is not the right angle, you just need to understand which of those two angles the number refers to.
Mike Harding wrote:
Solar panel angles
 Two angles???
 Ok, I know exactly what you mean.  Thanks Mike.
P.S. If you ever hear VK2KWJ on your Ham radio, let me know.
Do they have motors to track the sun in summer?
The satellite dishes all seem to be mounted horizontaldjn-0232-05423.jpg.
 Did not see any trackers, but maybe some.
Sat dish needs to point to the signal source.
Our solar panels are flat on the caravan roof. As far as I am concerned it is the suns job to find them. When the sun does not do it's job then my reliable Honda generator takes over. And it has no concerns for the angle ;) Even if it is snowing :):):)
We acknowledge and pay our respects to the British and European Elders past and present, who introduced civil society and prosperity to Australia.
Depending on the time of year and your location in Australia I'll wager you're losing around 30% of the capability of your panels, perhaps more.
OK if you're just a tourist/holiday maker perhaps but not if your caravan is where you live.
 So you can get all complicated with moving portables around all the time or making them tiltable or simply add another panel or 2 and forget them.
It's like trying to have a conversation with a fourteen year old.
I guess a 14 year old is pretty tech savvy nowadays, at least the ones I know. I agree with you about the losses of flat panels, and on top they heat up without airflow underneath and loose even more capacity, apart from the fact that they transfer a lot of heat onto the roof and into the van.
I can lift mine to up to 60 degrees and that's measured from the roof plane. Just by having cooler panels at 5 degrees is already a win.
regards
Gmd
If you find yourself on the side of the majority it is time to think.
As a result of Mike's original post, it made me think about my setup too.  I made a Solar Panel Sun Spotter out of scraps of things at home and then took some measurements of the sun's altitude each hour throughout the day.  I have documented the results in the attached PDF and included some pictures.  I can now point my Solar Panel at the sun, anywhere and anytime knowing it is catching the maximum amount of sun at all times (give or take).  Thanks for the tip Mike.
Nice idea Kevin.
However I think we're either going to have to find an alternative to the Frosties Fruit box or start eating them for every meal before we go into production :)
Mike Harding wrote:
Nice idea Kevin.
 Maybe you prefer Magnums. biggrin
The KISS principle solution is to instal sufficient panels to recharge you batteries during a normal day. Then there's no need to consult tables, adjust the panel angle and orientation of the van, nor any requirement to remember to secure it before traveling on.
Very true though I looked at the problem from the point of view that I had bits and pieces lying around my workshop which cost me nothing and it took only a couple of hours to put together whereas the cost of an additional solar panel was in the hundreds.  On top of that, the panel weighs 12 kgs and the gadget weighs 200 grams.  I tend to squeeze the last drops out of the toothbrush tube so thought I would squeeze the last drops of sunlight from the solar panel.  The piece de resistance is that I get to enjoy the creation of something useful from pieces of junk.  To me, it's very rewarding.  Simple things amuse simple minds.
I guess everyone is only considering solar panels best angle when camped. For me, not stopping very long at each camping spot, much or perhaps most of my solar power is generated whilst on the road and for that, I'm happy to have my 630w of solar panels flat on the roof. By the way, Peter, the satellite dish pictured is pointing at the satellite. look carefully where LNB is in relation to dish centre.
Roy.
No doubt getting the angle right has merit. But I just point my portable at the sun, best guess right angles.
IMO a combination of roof and portables is the best compromise. Roof panels must be pretty inefficient compared to a portable that gets moved 3 or 4 times a day.
Ill go lithium in a couple of years I think if the van is getting plenty of use.
Sta
Mike
Out of curiosity.
What do you get flat on ground compared to 60deg? (Worst v best)
Sta
oldbloke wrote:
Mike
Out of curiosity.
It is simply back of the envelope calculations.
Mmm, not sure. Does that mean if the panel is 25dec from perpendicular you only get abt 40% of max?
Sta
 Yes that is the general drift of it.smile
I also observed in previous years when I had loose portable panels that in strong sunlight the panels get very hot flat on the ground and the output is noticeably reduced by this effect. So when I played with them I got noticeably more current by angling the panels 'a bit' and allowing them to cool by the convection effect.  Sorry no actual figures to quote. But I did make some stands to hold them at an angle after that. aww
 You'd be aware Jaahn that the aspect of the panels, along with the time of year, has as big an effect as anything on performance. Cheers.
 Hi Yobar smile
Yes I am aware but was trying to be a bit non technical.
But here is the technical bit. The sun has roughly the same power, if it is clear full sun, from sun rise till sun set. Small differences but not significant. A panel will receive the full approx 1000W/sq meter power if it is square to the sun or close to it. But as the panel angle horizontal or vertical turns away from the direct sun, the power drops off (to zero at 90 deg). As was shown above the effective area exposed to the sun decreases. Not rocket science ! Your latitude will be important to determine the angle north to stand them up and has been discussed earlier in the thread.
So if you stand the panels up and facing the sun square on, approximately, from sunup to sun down, you can optimise the output. In practice say 4-5 moves over the day is enough. IMHO. The very fact of standing the panels up allows cooler running due to the convection away of heat, so power output is improved a bit by that too. This improved extraction of power by "tracking" the sun is well documented for the past 50+ years or more. When panels were very expensive, it was worth using expensive trackers. Panels are cheap now !
But as well there is a difference in the sun hours between summer and winter. The day is longer in summer and shorter in winter. This also varies depending on where you are, north or south. So in Australia down south you might have to track more in winter to keep up the power but in summer it might not be important.
cheers jaahn
https://www.solarreviews.com/blog/are-solar-axis-trackers-worth-the-additional-investment
-- Edited by Jaahn on Sunday 12th of June 2022 10:02:34 AM
From memory 1970s panels at Old Halls Creek.
When the sun hits & heats up the black tank the balance of the panels rotate to track the sun. There is a tank on the bottom left & top right of the 12 panel setup. It resets itself for the next day, simples!
