Post Info TOPIC: The Dark Absorber Theory
For years, it has been believed that electric bulbs emit light, but
recent information has proved otherwise. Electric bulbs don't emit
light; they absorb dark. Thus, we call these bulbs Dark Absorbers.
The Dark Absorber Theory and the existence of dark absorbers prove
that dark has mass and is heavier than light.
First, the basis of the Dark Absorber Theory is that electric bulbs
absorb dark. For example, take the Dark Absorber in the room you are
in. There is much less dark right next to it than there is elsewhere.
The larger the Dark Absorber, the greater its capacity to absorb
dark. Dark Absorbers in the parking lot have a much greater capacity
to absorb dark than the ones in this room.
As with all things, Dark Absorbers don't last forever. Once they are
full of dark, they can no longer absorb. This is proven by the dark
spot on a full Dark Absorber. A candle is a primitive Dark Absorber.
A new candle has a white wick. You can see that after the first use,
the wick turns black, representing all the dark that has been
absorbed into it. If you put a pencil next to the wick of an
operating candle, it will turn black. This is because it got in the
way of the dark flowing into the candle. One of the disadvantages of
these primitive Dark Absorbers is their limited range.
There are also portable Dark Absorbers. In these, the bulbs can't
handle all the dark by themselves and must be aided by a Dark Storage
Unit. When the Dark Storage Unit is full, it must be either emptied
or replaced before the portable Dark Absorber can operate again. Dark
has mass. When dark goes into a Dark Absorber, friction from the mass
generates heat. Thus, it is not wise to touch an operating Dark
Absorber. Candles present a special problem as the mass must travel
into a solid wick instead of through clear glass. This generates a
great amount of heat and therefore it's not wise to touch an
operating candle.
Also, dark is heavier than light. If you were to swim just below the
surface of the lake, you would see a lot of light. If you were to
slowly swim deeper and deeper, you would notice it getting darker and
darker. When you get really deep, you would be in total darkness.
This is because the heavier dark sinks to the bottom of the lake and
the lighter light floats at the top. The is why it is called light.
Finally, we must prove that dark is faster than light. If you were to
stand in a lit room in front of a closed, dark closet, and slowly
opened the closet door, you would see the light slowly enter the
closet. But since dark is so fast, you would not be able to see the
dark leave the closet. This is proof positive that the Dark Absorber
Theory is true.
So a black hole is a light absorber. Makes sense ...
Negative lights do exist.
In 3D scenes I sometimes use negative lights. Quite handy if a main light is over lighting an area, then use a negative fill light, with inverse square distance or what other fall off is needed.
Where the hell is Buzz Dark Absorber when we need him. biggrin biggrin
Rob
Chairman of the Bored
I know where there are a heaps of expensive Porsche electric EV's that desperately need lots of dark absorber treatment.
Steady 67, you will need the man who found the Titanic to know that
Cheers Craig
 Night is caused by the accumulation of "black air", according to the renowned savant, scientist and philosopher de Selby. He and his extensive theories are to be found in Flann O'Brien's novels The Third Policeman and The Dalkey Archive.
Excellent reading that sometimes makes you scratch your head in exasperated enjoyment at such witty writing.
Another theory of de Selby's was that mirrors held the secret to eternity, claiming a huge array of parallel mirrors allowed him to see his own face as a boy of twelve.
In The Third Policeman,one of de Selby's biographers is quoted as saying "The beauty of reading a page of de Selby is that it leads one inescapably to the happy conviction that one is not, of all nincompoops, the greatest.
See wikipedia for the above and more.
Enjoy!
The funny thing about this, being in the joke section, is that some people who read it will probably believe it, considering all the other rubbish that has been posted in other sections.
I believe it Buzz.
peter67 wrote:
I believe it Buzz.
 no
Buzz Lightbulb wrote:
peter67 wrote:
I believe it Buzz.
 no
 biggrin biggrin biggrin
Pardon the pun Buzz but you do need to Lighten Up.
Rob
It's true. All that science stuff I was fed at school was just a huge conspiracy.
Sta
 And yet you're using a computer to send that message. The current computers wouldn't exist without Quantum theory.
