Post Info TOPIC: Lithium batteries charging, discharging, balancing
This is a very long article, so be in the right mood to read it. There is a lot of information about lithium batteries.
Drop in battery issues.
Vibration.
Internal wiring.
BMS.
Life cycle claims.
Chargers.
Charging.
Discharging.
Voltage.
Alternator.
Storage.
https://marinehowto.com/lifepo4-batteries-on-boats/
As the article mentions, one spends a lot of money on lithium & you do not want to waste your money or have an even more expensive problem.
Thanks for that link. Long read with a lot to absorb. I'll be in the market for lithium in the next year. So this article has been very useful.
A link to Lithium battery teardown thread:
https://thegreynomads.activeboard.com/t67455852/lithium-battery-teardown-examples/
More information:
http://nordkyndesign.com/category/marine-engineering/electrical/lithium-battery-systems/
Nice link.
Great read on all things Lithium. One of the better links.
Well done!
Cheers, Richard (Dick0)
Drop in battery issues. Vibration. Internal wiring. BMS. Life cycle claims. Chargers. Charging. Discharging. Voltage. Alternator. Storage.
I could not have chosen a better heading to your blog. smile
I recently upgraded my Solar System to Lithium Batteries and Solar Charging.
I researched far and wide before undertaking the upgrade including seeking advice here.
I have consolidated my research of data and opinions into one document which I have attached for others contemplating installing a LiFePO4 solar system.
My solar system comprises of 800Watts fixed solar panels and one portable panel: a total of 1000Watts.
The Solar Charger is a MPPT Epever 80Amp charger.
The Lithium-Ion 2x135AH LiFePO4 batteries, in parallel, provides a 270AH battery bank.
I hope this helps somebody contemplating a LiFePO4 solar charge system.
I have included my detailed solar charger Lithium battery settings also.
Opinions and advice are most welcome.
-- Edited by Dick0 on Friday 16th of July 2021 06:26:32 PM
Thanks for that Richard
I have downloaded it, and will have a good read of yours, and Whenarewethere websites, when I am closer to purchasing lithium batteries
