Post Info TOPIC: Fitting a camera to the rear.
  • I recently bought a traffic camera to record whatever in front of my Mazda T 3500 mobile home.
  • All OK, except that I would like to fit one on the rear window, too.
  • How to connect to 12 volt at the back, that will turn on when the ignition is turned on.
  • That is, unless I run a wire from the dash to the rear !?
Any ideas !?
Regards.
Pipes.
Just run a 12V feed to the rear that is switched on with the ignition. That's what I did on my Mazda 323 for the traffic camera. Did it after an insurance dispute when some one reversed into the wifes car. You realy need video evidence these days.
-- Edited by DeBe on Friday 7th of September 2018 07:10:24 PM
D.L.Bishop
Pretty much your best option is to run the 12 V from your ignition to the rear. You are going to have to run the video feed anyway.
Too many stories about crap vision with wireless cameras to contemplate that route.
Being lazy & a tight arse I began with cheap wireless only to find too many hassles with reception, so I removed the wireless gadgets at each end and ran a video feed wire. I need a cheap 90 or less degree camera to give me a more "real life" look out the back.
Everything on this van is done "cheap" for proof of concept purposes so I know what we really do need when we go away for some major gallivanting. biggrin
Aussie Paul. smile
Have had a wireless camera on the back of the van for yonks now.
Must say that I was skeptical at first, so made arrangements with seller to
return no questions asked for full refund if there was interference. They readily agreed.
I was a bit skeptical due to the misinformation from cabled suppliers. Also, I had DIG's
TPMS that I thought might be on similar frequencies and might therefore interfere.
Mounted it up, powered from the sidelights, which are always on when I travel.
Was operating with the push of the pairing button and has never been anything other
than a perfect colour picture. Actually works with the two components 25 meters apart!
$260.
30,000 k and plenty of rough roads!
Google: DIG options.
https://www.digoptions.com.au/vehicle-cameras-monitors-accessories/
Kooka
-- Edited by Kooka on Tuesday 18th of September 2018 10:07:39 AM
I wonder if you would mind sharing with us which unit specifically that you used.?
$260.
Kooka
-- Edited by Petesahut on Tuesday 25th of September 2018 07:09:57 PM
-- Edited by Petesahut on Tuesday 25th of September 2018 09:12:39 PM
