Post Info TOPIC: What types of hot water systems are used in caravans?
hi, im new here so not sure how this works, but i would like to know how people heat water for caravans? thanks in advance.
jrg
If the van has an ensuite there will be a heater incorporated which runs on gas or 240 Surburan Trauma and swift are 3 brands I know of .
With no ensuite its, a billy ,Kettle or solar bag to heat the water the latter requires a high tree to get under it the other 2 are sponge or a bilge pump out of a bucket.
With the solar I used to place on the bonnet when stoped to assist from the bottom the heating process.all worked ok
 thanks jrg, much appreciated, i will look into electric i think.
There's another one called Atwood, not as common in Oz as the others but they are there. Its popular in America. Works on gas, 240 AC & 12 volts. However my new van that has this Atwood model & itdoes not work at all. Says a lot for the heater
We have a 14 litre 240 volt/gas Truma, very happy with it.smile
Santa.
240v / gas here .
Aus-Kiwi wrote:
240v / gas here .
Aussie Paul. smile
I have seen aftermarket replacement tap that connects to standard water supply and to a 240 volt powerpoint and gives instantaneous hot water, it could be fitted to any van.
Have not seen one for some years but would be worth checking with someone like Camac.
Diesel, waste heat from the engine and 750W electric power from the solar and inverter in a 22L storage unit.
Mostly heated from the engine as we drive and stays hot a couple of days.
 what is the electric element wattage of your 22l tank? is it just 750w? what brand?
regards,
Mark
This one.
www.surejust.co.uk/surecal
The wattage of the element can be chosen to suit. Ours is 750W which we can easily run when the sun is shining, but we rarely need to.
This one.
thanks for the link Peter, i am still learning about this topic and the various options out there.
regards,
Mark
 What is the model number of the one with gas, 240 AC & 12 V input? I suggest the 12 V input is just for the control board.
My old caravan did not have a built in water heater
I had two methods of heating water for a shower
On a cold day
I would boil a full kettle of water, add cold and hot into a designated bucket, and use a portable 12 volt shower pump
On a warm day
I would let the solar shower bag heat the water
I found that half filling the bag, heated the water much quicker, than trying to heat a full bag
