Post Info TOPIC: power connect to house
RE: power connect to house
Permalink Closed
Mike Harding wrote:
If you have to ask about it on a forum then you should probably stick to the rules.
 Good observation.smile
Santa.
Permalink Closed
Mike Harding wrote:
I think this is a case of... if you know what you are doing it's not an issue.
Certainly a case of not recommending it to be done by all or giving a cheater lead to someone thinking you are doing them a favour. Better they gauge their own knowledge level and situation and make a decision from there, then the blame sits squarely on their shoulders if anything goes wrong because they were informed of the risks and chose to ignore them anyway.
T1 Terry
-- Edited by T1 Terry on Saturday 17th of March 2018 07:18:07 PM
Permalink Closed
As the plugs within your vehicle are 240v 10amp, whats wrong wirh passing a 10amp extension cord through a window and plugin say the fridge, wouldn't try to run all appliances at once.....
Daryl
Permalink Closed
Hi smile
There cannot be much more to say on this subject.
My only comment is that after having a real story told about the consquences of doing the simple illegal plug change and then trying to justify it, is some people never learn.
I would also say publicly announcing to the world, on a forum, that you are doing something  illegal and promoting it seems just stupid in itself.
Permalink Closed
T1 Terry wrote:
As far as the Amphibian goes, isn't there something in the standards about multiple extension cords not being legal for a transportable premises? I'll leave that to the standards police to add the "Shall" and "Shall not" where applicable and explain the logic and how this gets around the legalities
Yes there are standards prohibiting joining power leads supplying power to a caravan.  However the Amphibian is considered to be a power supply board and not an extension lead. It must be plugged into a power point and you are only permitted to connect your van to it via one power lead.
Permalink Closed
Dick0 wrote:
A suitable cable, 15A socket & 10A plug does the job well. Why are these parts sold in the first place? As far as I know there are no restrictions making up your own extension leads. My electrician mate has done the same!
 The parts are sold to construct devices that comply with the law. Not to jury rig any Heath Robinson device that anyone  conceives.
As to restrictions in making up your leads, there are certainly restrictions in NSW. Only licensed tradesmen are permitted to construct leads. I suggest this is the case in most states.
If your mate has been constructing these devices he is leaving himself open to loosing his licence.
Permalink Closed
biggrinbiggrinbiggrin
Lotsa naughty farmers are going to get their wrists smacked. lol
smilesmilesmile
Cheers, Richard (Dick0)
Permalink Closed
Jaahn wrote:
Hi smile
 There must be hundreds of stupid people out there with this set but were on the internet and so you can get away with stuff you would not dare say to an individual to there face...
Permalink Closed
If you only need to charge the battery just use a normal battery charger direct to the battery with a 10 and lead.
Sta
Permalink Closed
smilesmilesmile
Me included Dick0 many years ago. You just have to make do most of the time. biggrin
Aussie Paul. smile
Permalink Closed
chugger wrote:
I hope someone might clarify something. I've heard that I shouldn't connect my motorhome power source to our house power source with a standard extension cord, without an adaptor, due to differences in amps (10amps in van, 15amps in house). Is this correct? If so, do I need one of these adaptors to plug in at a caravan park? Thanks in advance.
 How would your 15A  extension lead plug fit into the house 10A socketbiggrin [It will not fit], so you do need an "APPROVED" !0 to 15A adapter such as an" Ampfibian"
It shall be  plugged directly into the 10A  house socket then  15A extension lead to van
But ALL cps should have 15A outlets ,so the normal 15A  extension lead is ok
Permalink Closed
 The logical and legal/safe way of going about it is to have an electrician install a 15 amp power outlet, problem solved.smile
Santa.
Permalink Closed
 Ditto
Such device  have a specific Aus Standard that they must comply with ,[NOT CLASSED AS AN EXTENSION LEAD]
They SHALL be connected direct to the  power supply socket
Any one with an understanding  of basic electrics should understand the differences & why that location is specified.
Best for those who do not understand  ,due to lack  knowledge, to just follow / comply with the rules & regulations drawn up by those who have real working knowledge  of the reasonsbiggrin
Those with the knowledge would understand  how  factors such as  ,voltage drop  ,fault loop impedance, current overload protection, IP rating, need to be met.!!
Note, the multi outlet power boards such as Clipsal , Arlec , etc, do not comply  for such use & are covered by a different standard.[in fact are specifically referred to as not being approved for use with "transportable structures"]
-- Edited by oldtrack123 on Monday 19th of March 2018 11:24:14 AM
Permalink Closed
 Using the correct  "Approved "Ampfibian" for the situation  is fully acceptable[legal & safe]
But  best to get the weatherproof model that can be used in all situations [under cover or exposed to weather]
It also has the advantage that it can be used anywhere where only a 10A outlet is available
 Take it with you if staying at friends places or some show grounds ,etc
Anyone changing or making up a 10A plug 15A socket EXTENSION lead is breaking the electrical regulations of EVERY Australian state
Could be in deep s*^t if caught plus insurance void
-- Edited by oldtrack123 on Monday 19th of March 2018 11:20:49 AM
Permalink Closed
smilesmilesmile
Aussie Paul. smile
 Hmm
Making do ,while deliberately ignoring rules & regulation can have nasty consequences ,especially where insurance or injury occurs traceable to that "make do" no
Permalink Closed
PeterD wrote:
[1] The parts are sold to construct devices that comply with the law. Not to jury rig any Heath Robinson device that anyone  conceives.
[2]As to restrictions in making up your leads, there are certainly restrictions in NSW. Only licensed tradesmen are permitted to construct leads. I suggest this is the case in most states.
[3]If your mate has been constructing these devices he is leaving himself open to loosing his licence.
 DITTO to
[1] Dicko, Have you seen the warning in many stores ,especially Bunnings , regarding using such components[pointing out it is work for qualified persons]
[2] Ditto ,in ALL states electrical regulations
[3] Yes ,& deserves  to suffer severe penalties for KNOWINGLY breaking the regulations or is he plain stupid,& does not understand the basic reasons why such SHALL NOT Be made up /available???
But always some who will do anything for a $$
An instance  of such ,a northern rivers electrician  running a solar & electrical business was openly advertising,on line, the components in kit form with instruction on how to make it up [with a nice big $ markup]
Some one tipped of the NSW  Authorities
Within in 3 weeks the advert disappeared & that business can no longer be found
-- Edited by oldtrack123 on Monday 19th of March 2018 11:45:06 AM
Permalink Closed
smilesmilesmile
Aussie Paul. smile
 Some 10 years ago, farming was  second on the list of most likely to be killed at work occupations. ( short cuts & she'll be right might have a lot to do with that )
Cheers Pete
Permalink Closed
Ron-D wrote:
[1]Just one final note this lead connects to a single 240 outlet in my garage when needed its never in the weather ,its only needed rarely to top the battery up,
[2]the house is fused with safety switches the caravan has its own trip switch
[3],how the Hell could this thing give any trouble its been in use for ten years three caravans,my fingers when connecting only touch the switch after the cable is connected , when disconnecting the switch has been turned off before fingers even touch the cable. Illegal maybe?
[4]Unsafe no way....
-- Edited by Ron-D on Saturday 17th of March 2018 03:21:20 PM
 Unsafe ,  because overloading the 10A wall socket can /has lead to fires
One of the reasons that all those small multi outlet boards NOW must have an inbuilt 10 AMP circuit breaker
[1]The possible misuse of such a lead & overloading it  & the 10A outlet is the problem.
Fire, electric shock possible!!!
[2]totally irrelevant !! they only give overload protection to the circuit wiring
No protection to the 10A outlet
[3]That has no relevance, the risk is fire at the 10A outlet!!!
[4] Totally incorrectno
Very good reasons why such set ups cannot be bought. ,anyone selling one would be in real trouble for selling something that is not/cannot be approved
Any electrician ,even making one up for a friend ,could / would be in big trouble if found out
Good reasons for having standards are :
[a]protect innocent parties from other's stupidity. [fire , shock,electrocution]
protection  of property,  Electricity,misused is the source of many ,many house fires
then there is an overriding reason why such should not be available,even IF the current user "thinks" they understand the risks, & that is that someone else could get their hands on & be totally unaware of the risks
eg those kind people, who leave it with their van when they dispose of/sell it!
For a time ,,had just such a know it all son in law
Multiple double adapters off the kitchen power point , running multiple high current appliances @ the same time
I explained  the dangers to my daughter who understood  & did not use them ,but smart A knew better until he found  the outlet smoking & worse the switch no longer worked
He had to rush outside & turn the main switch off
I wonder where their house would have been if he had not come in when he did.
PLEASE ALL ,understand that the rules ,regulation ,& Standards are there primarily to protect lives & property.
They are not drawn up by fools, but have wide input from people knowledgeable in the respective fields.
They they go through a rigorous  process  of examination  & comments before they become official Standards.
They are regularly revised,  or amendments issued ,if the need/ circumstances arises
-- Edited by oldtrack123 on Monday 19th of March 2018 01:51:09 PM
Permalink Closed
Amazed how this SHOCKING blog just keeps going...lol...confuse
The POWER of the forum is to ENERGISE an ELECTRIFYING discussion and CHARGE thoughts to JOLT and STUN those WIRED to a POINT in avoiding a ZAP.
-- Edited by Dick0 on Monday 19th of March 2018 02:16:53 PM
Permalink Closed
Yep never hertz .
Permalink Closed
 Hi Daryl
I think you are saying plug the fridge directly into the extension lead socket??
That is not illegal  [ just plugging in ONE item] ,but has some risks, if the cable is not well protected from mechanical damage, such as the door or window being closed on it & pinching/ deforming / damaging  the insulation.[both outer & inner cable insulation]
That damage may not show up immediately
Permalink Closed
Oh please ^^^ This is an issue with any lead !! Elect drill , vacuum cleaner .
Permalink Closed
  What a stupid  statementblankstare
Suggest you reconsider what you are saying.
YOU claim to be an "electrician"noconfuse
Exactly what are your "qualifications"???
IF you cannot see there is a difference ,GOD help anyone you do electrical work for, or  give advice to
 To other  readers , watch out,  ask any one who claims to be an electrician to show you what he is qualified to do.!
There are quite a few classes of "electricians"
Each class has limits on the type of work they are allowed to  do
[a]limited electrical licenses licensed to only do very specific tasks .
Like connecting & disconnect fixed wired appliances .
electrical lines  man.
[c]meter  & mains connecting  etc
[d]up to fully licensed ,they are allowed to  do all classes of low voltage electrical work
-- Edited by oldtrack123 on Monday 19th of March 2018 04:59:15 PM
Permalink Closed
nonono
Oh man, oh man, oh man...where is this going?
Why the abuse?
Don't upset yourself unnecessarily over triviality.
We are just giving personal opinions.
Any more sparky cops out there? lol
confuseconfuseconfuse
-- Edited by Dick0 on Monday 19th of March 2018 05:14:58 PM
Permalink Closed
Just as well the  "OP" asked a simple question. smile
David
Permalink Closed
David
Too right. lol biggrin
Complicated technical questions are even too much for the "qualified experts".
hmmhmmhmm
Permalink Closed
Hail the Safety Nazis.
He'll wear himself out in the fullness of time.
Nothing like the righteousness of those with God on their side. But... damn! they are boring and tedious....
Permalink Closed
Haha. biggrin
The comedians are far more fun than the XSpurts.
Are we off topic?
Permalink Closed
cry
Sorry chugger...
A big welcome to the Forum.
Hope you got the info you sought.
Got a bit off topic.
I gather the "Ampfibian" is the "legal" way to go. biggrin
smilesmilesmile
Permalink Closed
PASS!
«First  <  1 2 3  >  Last»  | Page of 3  sorted by
