Post Info TOPIC: 350Amp Anderson plug?
gday,
I just purchased a 2nd hand Landcruiser which has an exhisting 350Amp Anderson plug. Can somebody tell me what this would be used for? I'm thinking of removing it if I don't have any need for it.
many thanks
Maybe for a winch? That is a very high current plug, and about the only thing that draws heaps of current is an electric winch. Where is the plug located?
David Irvine
Tugs: 2016 Discovery 4./2017 Toyota 76 GLX Auto Wagon. Van: New Age Manta Ray Deluxe
It's near the towbar on the back.
Probably just something the previous owner had lying around in their shed and figured it will do. My father in law was an electrician and for the trailer plug on his box trailer he used a 3 pin electrical plug - park,stop and earth. This was before blinkers were common.
Good Luck.
I've seen some pretty heavy plugs on fitters vehicles for jump starting equipment with 24v systems. There'd be a couple of big batteries in the back wired up as the 24v supply. There'd be a matching plug on the equipment.
Probably a left over from a bored DIY retirees meddling. Get rid of it & visit an Auto Electrician to trace the wiring for your peace of mind.
Cheers Keith & Judy
No fun in that DDbiggrin
Aussie Paul. smile
The Master
It would be a 50 amp grey Anderson plug to supply power to a campertrailer or caravan to charge it's batteries.
Happy Wanderer
Don't worry, Be Happy!
They are often put on mining vehicles. Used to jumpstart others Or power lighting.
Often used on Roas Service (NRMA) type vehicles, for jump-starting etc.
Most likely used for a boat winch.
I'm more curious in what size cable is in the plug?
6mm cable
Hmm, have to agree with what hako said earlier... was probably something left lying around that would do the job... or words to that effect.
6mm won't even get there over the distance !! Maybe run a fridge ? 8 amp max over distance., Dreaded VD !!
I have 400A Anderson plugs front and rear of the OKA for a movable winch.
But it also has 50mm2 cables to it.
