Post Info TOPIC: Domestic frig door
Domestic frig door
Domestic frig door has fallen off any help?
Photo's
and what yr\model??.
"DomeStic" or Dome-tic.??
Hello Graynmarge
Welcome to the forum
As macka17, above has already said
If you supply a model and number, someone with that particular model may be able to give a few tips
In a normal situation a fridge door has two hinges, one at the top and one at the bottom
It is normal to place the door on the bottom hinge, and then there is some method of fitting, and tightening the top hinge
The door falling off, usually means that one of the hinges has come loose
I know nothing of Domestic brand caravan fridges
But the Dometic brand caravan fridge, has plenty of information on the net
Hope that this info is helpful to you
It's pretty obvious, get a new fridge. If the door has fallen off a refrigerator it must be ready for the tip.
Cheers Keith & Judy
DD, that's a bit harsh you don't even know how old this fridge is - if it's only something as simple as a broken hinge and everything else is working why would you want to throw it away. Not everyone can afford to run out and replace something as their first option, maybe that could end up being the final outcome but why not see if it can be fixed first.
DavRo
Aussie Paul. smile
Did you actually go to school????
Hi, allways had problems with my fridge door when we first bought the van, the previous owner never let on there was a problem and l didnt check....anyway it was an easy fix as the top hinge was partially broken
The steel male part attached the the fridge was fine , it was the plastic female recieving part attached to the door was broken
l was going to buy a new part but it was hard to find the part on sites , so l did some research and found a 2 part epoxy type stuff that sounded great ( set hard hard could be ground/sanded etc ) and Buninnings actually had the stuff there......l'm at work and can't remember the brand , but can let you know if need be............any all l had to do was take the male part off the fridge to use for hole size and mix the 2 parts of this stuff into paste , then slap the paste into the broken area , get it clean and level, then insert the male shaft ( with silicon sprayed on it ) and make the desired hole shape, then gently pull out....it did sag a little bit , but l justused a nailto push it back .
When it dried and set , the next day l just ran a drill in to get it nice and even............worked great :)
Aussie Paul. smile
Yes I have an Associate Diploma in Structural/Civil Engineering. I also write articles & provide images for various nature based internet sights & magazines both in Australia & overseas.
Cheers Keith & Judy
Cheers Keith & Judy
 Rode scholar - Rode through on a bike lol
 ?   What's this about.
How did we go from fridge door question to this.  !
Mike & Ellie
 I think it's mainly because, despite their advanced age, some individuals have not matured sufficiently in order to be able to keep their egos in check.
Frankly; they are a pain in the arse when they behave in this childish manner.
DD is it "sites" not sights?
biggrin
Dave & Addy
Travel Blog: adrienne4dave.wordpress.com
Sorry Graynmarg, being new to the forum you need to realise that some people get a thrill out of hijacking posts by making sarcastic comments, maybe you should just repost your question under the techies area. As Macka suggested if you are able to provide a model number people who have some genuine knowledge or experience with this problem maybe be able to offer you some proper advice just as Kessa32 and Tony did.
cheers BB
DavRo
