Post Info TOPIC: Genset battery expensive!!!
The battery in my genset is only 51mm wide, where most are around 65mm.
A "specially made" battery for $55!!disbelief This battery is L 150mm, W 51mm, and H 93 or 107 to top of terminals.
Thinking about how to get around this with maybe a cheap Lithium jump starter. Might burn the place down though.no
Thoughts?
Aussie Paul. smile
Have a quick look at motorbike battery's mate.
Could be lucky.
Otherwise. Like me.
Pull the string. I ALWAYS buy manual start genny's.
easy to pull over. AND less to go wrong
Even my big Dirt Bikes were always kick start.
Has it got some sort of model number on it. Don't think I've seen one without a number. Will give you an idea what to replace it with
Dave
Dave
 Aussie Paul. smile
Could be lucky.
Otherwise. Like me.
 I can't help it of you are silly Macka!!biggrin
Motorbike batteries seem to be wider than 51mm.
Aussie Paul. smile
Just had a quick look on ebay and there seems to be some available
NEW-6V-12AH-UPS-SLA-battery-6-volt-gt-7ah-9AH-Solar-Power-Scooter-ride-on-toy
New Vision 6V 7AH Sealed Lead-Acid Battery AGM UPS APC Alarm Toy car 7.0ah 20hr
Sorry, just noticed that the ones I looked at were 6v.
Cannot seem to find the smaller width in 12v.
-- Edited by Hewy54 on Tuesday 8th of November 2016 07:22:45 PM
Can old battery box be modified ?
 No Aus-Kiwi, no room to adapt!!no
Aussie Paul. smile
-- Edited by aussie_paul on Tuesday 8th of November 2016 07:34:37 PM
Can one be fitted outside ? Is it built in ? Then get supply off house . Motor batteries ?
Can be fitted to handle, I also have an anderson plug connected so can be jumped. atm I start it with lipo jump starter.biggrin Unfortunately the lipo jump starters do not charge via the output alligator clips.no
Aussie Paul. smile
Hi,
Can you adapt a cigarette lighter plug & lead to connect to the alligator clips to charge your lipo.
David
Could it be one of these
www.powerstream.com/Size_SLA.htm
Dave
Hi Paul
Have a look at Jaycar
they've got them in stock
Cheers John
Status: Online
Thoughts?
Aussie Paul. smile
 Hi paul
My first thought would be don't by a battery, fit a anderson plug to your gen set and just jump start it from the 2nd battery in the tow car or from the caravan house batteries.
I have my caravan fitted with a couple of anderson plugs,  I can run a inverter from, the portable frig, charge the caravan house batteries up, run a 12 volt air compressor for example.
Hope this may help.
Cruising Cruze wrote:
Hi Paul
Cheers John
John, I can't find one 51mm wide no
Aussie Paul. smile
Radar wrote:
 Hi paul
Hope this may help.
I do have an anderson plug connected to the genset so it can be jumped.
Aussie Paul. smile
Hi Paul
Found this that is near the size you are looking for.
www.batterydoctor.com.au/store/drypower-12v-7ah-narrow-terminal-sealed-lead-acid-high-rate-battery-for-standby-and-ups-replaces-hr1218w-hr1224w-lpl12-4-5-wp1224w-up-vwa1232p2.html
Vince
Cheers from Vince
VK2FBUZ
Vince wrote:
Hi Paul
Vince
Thanks Vince. Now I have a backup plan.biggrin
Thanks everyone for your thoughts. No one was game to go down the Lithium path.nobiggrin
Aussie Paul. smile
Always game Paul biggrin
https://hobbyking.com/en_us/zippy-flightmax-4200mah-2s1p-30c-lifepo4-pack.html
which is 52mm -would that fit? or check some of the options on the website.
I would add a switch to isolate the battery from the genset after starting so it doesn't get charged.
Charge it with one of these https://hobbyking.com/en_us/imax-b6-ac-v2-charger-discharger-1-6-cells-genuine-au-plug.html
IMHO the motorcycle LiFePo4 batteries do not bode well in operation, they fail too early due to overcharging voltage.
Lead Acid motorcycle battery (or UPS battery) would be your best bet though, drop in -if you can find a fit
Gday Paul, hope you are well mate.
I bought a small 3AH 12V sealed batt for $20 from battery world for a mobile supply, tiny little thing should have enough guts to crank your genny, however it would need a charge each time.
I read your memories in facebook mate, was that an ultralight those many years ago?
Cheers mate
hy-battery.com/en/productDetail.asp
Just a start
Cheers Chris
 https://chrisanddiannesultimaadventure.wordpress.com/
I wouldn't have to manage my anger if people managed their stupidity
Cheers mate
 https://youtu.be/NQO-3DgG7Go
Aussie Paul. smile
Cheers mate
 Phil, would it charge from the genset like the original one does?
Aussie Paul. smile
I think it should. If the old sealed batt did I recon the new one will. Depends on the charging system on board the genset. I would check that out first, like the delivered voltage and if its a constant current or constant voltage charger.
Saw the vid mate, love autogyros.
Glad you enjoyed the vid
You wouldn't happen to have a part number for that battery would you Phil?
Aussie Paul. smile
Hi Paul,
I cant find the bloody thing to get you a part number, however if you go to battery world they have these for sale. From memory they are about 2.5 to 3AH 12V sealed gel batt.
Sorry mate, we have just had a big clean up and its lost in a box someplace.
Phil C wrote:
Hi Paul,
lol, know the feeling Philbiggrin
Aussie Paul. smile
As soon as I find it I will post a pic for you...
