Post Info TOPIC: Power surge
Power surge
had a power surge today 55% in batteries at 730 full by 1145 .biggrin 400 amps lithium
dibs
gdyble
dibs
Roughly an average of 42 amps for 4.25hrs, I guess you didn't get that for the first few hrs so it must have been charging hard in the last 2 hrs, gotta love the high acceptance rate of those lithium batteries. Now what are you going to use the rest of the days solar for, heating the water or run the air con.... or both? These lithium batteries have brought problems all of their own eh, you never had to think of these things before they came along, perhaps you should go back to lead acid so you don't have to think about these things :lol:
T1 Terry
Get nicked there not going anywhere I don't go .
Dibs
gdyble
If you have any problems with heat if you have excess input after water heating.
I have a coupla big "dumps"here from solar/wind/panels in yachttie days.
They what marine Tech installed for such on boat.
Would be just the thing?.
In most cases I'd expect the excess solar was due to long hrs of sun so the air con would be the other load to use up the excess solar. Big heat sink dumps were the way many yrs back but these days even wind uses electronic control to limit the output by either pulling the generator out of the wind or changing the prop pitch  or simply locking the output so the load is greater than that generated and simply stops the turbine spinning fast enough to generate anything, sort of turning the generator into a motor using the current it generated to drive the motor.
I'm guessing the big heat sinks were in the water at all times to dump the heat, no where for that other than the ho****er tank on an RV
T1 Terry
How strange, hot water is blanked out with **** like it was a dirt word, but then on another place T1 was a dirty word for quite a while :lol:
-- Edited by T1 Terry on Friday 11th of November 2016 05:35:11 PM
Terry, you had hot water joined as one word - check which letters were replaced by **** and you'll see why the overzealous forum censor software blanked them out.
Joe
Joe
:lol: we live in interesting times that's for sure :lol:
T1 Terry
Terry is there a gauge that will collect usage over a month so I can charge della for how much she uses lmao.
Dibs
gdyble
