Post Info TOPIC: Need a coffee machine!!!
The other half wants a coffee machine for the van.
Can anyone recommend  a particular model? Preferably not a pod type as we like to brew to our own strengths as we do at home. Have been looking at a delonghi at HNs but the reviews weren't too good which is a pity as it wasn't much bigger than a pod machine.
Appreciate any help.
Welcome to the gang usand2dogs, enjoy here and out in the playground.
Not being a coffee drinker I will leave it to others to help you out.
What about
www.rokkitchentools.com
Looks simple. Not tested by me but has good reviews.
Weedpharma
Hello usand2dogs
Like Dougwe has already said, welcome to the forum
Also like Doug, as I do not use a coffee machine, I can not comment on the best type
I am sure that those who have a coffee machine, will let you know of a few good brands to look at
Welcome us and 2 dogs we offer you a warm welcome to the forum as for coffee machine I do use a pod machine that I purchased at Aldi and there are pods other than Aldi ones that fit this machine, they are also reasonably priced and last well mine is now 4 years old and cost around $90, worth considering.
Thanks Weedpharma. I will investigate further.
Thanks for the welcome.
We just spent our first weekend in our first caravan and we missed our nightly caffeine hit. The old instant doesn't quite cut the mustard.
One of the secrets of a good cappuccino is the stretching of the milk. Milk is not frothed, it is "stretched". This is what lets the pod machines down, for me anyway.biggrin
Aussie Paul.smile
-- Edited by aussie_paul on Monday 10th of October 2016 08:42:19 PM
-- Edited by aussie_paul on Monday 10th of October 2016 09:15:49 PM
We have a Breville coffee machine the same as the one below in the link - it is a manual machine so you can make your coffee as strong or weak as you like and it steams milk as good as any of the others. Best thing is it's light, takes up not too much space and well under $200. Despite all the hype, most if not all machines use exactly the same process to produce a cup of coffee....the only difference is the price.
https://www.thegoodguys.com.au/breville-cafe-venezia-espresso-coffee-machine-bes250bss
we use a stainless steel French press or a stainless Italian pressure stove top both give good coffee take up much less room and unbreakable
KFT
We have been using one similar to this for quite a few years now. http://dibartoli.com.au/bellman-cx25p-stainless-steel-stovetop-with-gauge/
It makes a cappuccino or a flat white a long or short black just like the powered machine at home
The beauty of this style is you can use almost any heat source to make it work. I usually use ours on a single burner gas cooktop.
hope that helps
Frank
-- Edited by KFT on Monday 10th of October 2016 11:23:39 PM
-- Edited by KFT on Tuesday 11th of October 2016 09:57:08 AM
-- Edited by KFT on Tuesday 11th of October 2016 09:57:31 AM
Avagreatday.
I am no coffee expert but I have discovered that the price does not alway guarrantee quality. I have purchased "domestic" machines costing $1000+ and they have let me down. I have purchased the "known brands" and they also have let me down. The area they seem to fail in is how they make steam. Some use a mechanical pump to create pressure or 15+ bar as they call it. These machines are easily identified as they make thumping noise as they make the steam. The good machines have 2 boilers. One to make the coffee and one to make the steam. These do not make a pumping sound when creating steam. If you cannot afford a double boiler model then a single boiler one is OK. It just takes half a minute to change the boiler from coffee extraction to steam. I have used and they have broken down or failed to work properly a Krupps, De longhi, Breville, Saeco, and they all failed. To get them fixed was as dear as buying a new one. I then went to a barrista course and discovered Rancilio. They make commercial machines as well as semi domestic. This has proper boilers and I have had it for over 5 years. It makes great coffee but it is not cheap. You also need to get a decent grinder as the cheap grinders do not grind fine enough for this machine. Having said all that, I am quite impressed by the pod machines. Lots of resorts have these and they do make a reasonable coffee. However, I am told the pods can cost the earth and soon the cost of the coffee outweighs the cjheaper unit. Also with coffee machines that use grind coffee, you can purchase a mix you like from a decent coffee shop. Pods you just take what they put in. At the end of the day I like my cafe Latte, but I am also quite happy with a caffine fix of blend 43 if thats the only option.
David Irvine
Tugs: 2016 Discovery 4./2017 Toyota 76 GLX Auto Wagon. Van: New Age Manta Ray Deluxe
Aussie Paul.smile
usand2dogs, I have witnessed Paul "Stretching" his milk. The only problem he has is the milk spilling on the floor as he tries holding one end in one hand and the other end in the other hand.
G'day KFC, mate.
Google Aeropress.  They make a fantastic coffee maker that doesn't use power, is compact for the van and produces a great quality coffee.  I use mine daily.
If you finally have to go to a pod consider the ALDI machine. They have a large choice of pods from very weak to very strong. You would find one you like.
Have had coffee machines but found I still used my nestle 43 more than machine.
Mechanised Swaggies
hi usn2dogs,
welcome to the playground. I prefer to buy my coffee from a coffee shop. Good luck finding what u want. Cheers. Rocket n strop
At home I brew my own, in the camper I use a Pod because of space. Not sure how good the Aldi Pod machine is but I have tried a strong short black from their range of Pods, superb.
KFT
This is what the Bellman looks like
-- Edited by KFT on Tuesday 11th of October 2016 01:44:19 PM
Avagreatday.
I've been using a very old Breville drip machine which I purchased at a Sunday Market for about $5.00, back when Adam was a boy. However having being graced with extra funds from Centrelink, a $2.60 a fortnight increase in the Age Pension, I decided to lash out and buy a new machine. I purchased a Sunbeam Model PC7900 from Harvey Norman for around $60.00. Attached photo. Highly recommended if you require a basic machine for the morning coffee. Can make up to 12 cups.
-- Edited by Big Gorilla on Wednesday 12th of October 2016 12:07:25 PM
 I just use instant 'Nescafe Gold Intense Barrister Style' .. sounds good & tastes OK to us.
I am too lazy to use the Aldi pod thingo that sits in the home cupboard beside the old fashioned plastic drip perculator & then there is the old glass drip perculator that Mother used to use.  Several packets of ground coffee in the freezer, only a few years old too.
But this looks interesting ..  good reviews too ..
Not really into coffee ,,, Does it show?
PS .. My first encounter with pod machines was in Boston where I managed to stuff up the first machine but the room service guy kindly & without comment gave me  personal instruction on the replacement machine. So I became the instant expert for the rest of our traveling group.
Perhaps this may help http://www.talkcoffee.com.au/buying-guide-espresso-machines/   appliance type espresso machines are notorious for problems and short life span, as with most things, you get what you pay for, good luck with your search.smile
Santa.
Gday usand2dogs
Like Dougwe has already said, welcome to the forum.
Unlike Dougwe (who is a mate and great bloke!) I love my coffee. I went to woolworths and got a Caffitaly machine on special ($99) and it produces nice coffee in the mornings and whenever the craving kicks in. Pods are around $6 for 10 or 16 (depends on how you buy them. I have found "grinders" brand to be the best.
Machine works well on my genny and inverter when we free camp.
BTW, just between you and me, Dougwe has no taste in cars.
Keep on slurping that caffeine.
I use a French Plunger type pot.  Also grind the coffee beans with an electric grinder.
I was given a Pod type machine  three years ago for Xmas,  and was not all that impressed with the price of the coffee pods.  Asked my nephew if he would like it back as I never used it after the first lot of Pods I bought were gone.  Theirs had just Karked it,   so he grabbed it.
They I have  noticed now have two machines.  The big one does the works,  bells and whistles included,  also the Pod one I gave back to them.  "Coffee anybody !"   they ask,      and they make you Instant Coffee,    cos it takes to long to make 6 cups  on any of the machines ?
 Further more I have never been impressed by the temperature of the delivered coffee from most of these machines  (Grounds  or Pods) as I like coffee HOT.
 Added to that the  disposing of the Pod  after use was not in my way of thinking good for the environment. I notice there is a rising concerns over the pollution caused by these Pod containers.
I will stick to my Plunger Pot and Coffee Grinder,  it suits me  still to make it that way.  I drank Black coffee from I was about 15 till just about ten years ago (57 years)  when I started to enjoy it with Cold milk added.  Never been into all the fancy frothy coffee's.
Good luck with your inquiry,  and Happy Morning Coffee breaks in the future.
I thought this below was a laugh
http://www.cbc.ca/news/canada/nova-scotia/kill-the-k-cup-video-aims-to-show-environmental-impact-of-coffee-pods-1.2899027
-- Edited by elliemike on Wednesday 12th of October 2016 03:17:20 PM
Mike & Ellie
 Welcome to the Forum from this neck o the woods also :) , so many pointers towards a coffee machine and can go on and on :)...Just get one that you can get the  grinds in , packs the coffee in , and steams or stretches the milk as previouse stated .
The secret is not to burn the Milk :) when you froth/stretch it..
A good Coffee bean/grind  and a little knowledege in making your own will tell if you keep your machine or dump it after a few uses..
I started making Cappicheeeeeeennnnoooos at the ripe ol age of fourteen in the Town Of Golburn N.S.W. , hundreds a day especially come lilac time doing fourteen hour shifts :) and second nature making a good Cappy even at this ripe ol age :)...
My wife won't go anywhere without her Nespresso Pixie.
www.nespresso.com/au/en/pixie-machines-range
