Post Info TOPIC: Will a second battery double my storage?
Hello all
i have a 120watt panel on the roof of my new manta ray van and a 100 hour battery, my question is if I get another battery will I get 200 hours of storage?
all I need is a very simple answer, I understand it will,depend on what I use etc but just keep it simple.
Brett
Live your life, not someone else's.
@brettsworldtour
Hi Brett
Trying to keep it simple usually comes with some caveats, but I'll try and get things started by drawing on what I've learned from this great forum over the past three years. Yes, another 100 a/h battery will double the storage, but this will mean that your 120W panel will have to charge two batteries instead of one, so you should consider another 120W panel if finances and roof real estate permit (perceived wisdom is that total panel wattage should at least equal your total battery a/h capacity). Ideally dual batteries should be the same make, capacity and age. If you can advise what equipment you'll be running, particularly fridge (compressor or gas), TV and other appliances will allow others with more knowledge than I to give more detailed advice. Knowing what solar controller (make and model) you currently have will also help.
Joe
Shogun wrote:
Hello all
Brett
 Hi Brett smile
Keeping it to a simple one sentence, yes it will double the storage on paper but you may not get the two batteries fully charged because you have minimal solar to do it, so it may not actually be doubled except in extra good conditions !furious
Thanks for your advice much appreciated. I'll double the battery and panels me thinks :)
Brett
@brettsworldtour
Is battery charged through the day but goes flat or low over night ? If solar charges to trickle by say ? mid day . Then more storage . I would add more battery and solar . Adding another battery is like having two bank accounts . Solar is not expensive now . Chances are the cables can be pieced into or just add connectors ?
 That is actually a good analogy.
One person opening a 2nd account won't give any more reserve, will just split income (solar charge) between the 2 accounts (batteries).
The 2 accounts (batteries) are worse off as fees double and neither really increase in value until a second person (panel) contributes.
Neil & Lynne
Pinjarra
Western Australia
One account for me the other Mrs. Lol yea lol
Just make sure the regulator can take the dual output.
120 x 2 =12a approx.
You never get full solar power efficiency though ..
Brett, your Manta Ray will more than likely have a 30 amp regulator and able to run 3 x120 watt panels. It's pretty simple to put another panel on the other side near the door and join that panel into the existing wiring with a couple of 2 into 1 joiners from jaycar. eBay etc. fitting another battery is simple as well. Are you running anything more than just the lights, pump, TV?.
Jon
Thanks for that Jon, not running anything apart from my CPAP at night. I'll Suss out a few panels to see what will fit.
Brett
@brettsworldtour
Check that the new panel(s) are similar Vmp to the existing one before you buy.
3 panels would be more value to you than 2 batteries....you can not use energy that you do not collect.
Do you use the humidifier on the CPAP? This is the bit that uses most of the power.
BTW, the second bank account description should be attributed to Collyn Rivers....
Hi Peter, don't use the humidifier when travelling only at home. I currently have a 120watt panel on the roof and was wondering could i get a 200 watt as well or do i need to get another 120?
Brett
@brettsworldtour
Brett, you do not have to match the existing panel if you have a PWM controller. All you have to worry about is you add a panel with a similar open circuit voltage.
Thanks Peter
@brettsworldtour
