Post Info TOPIC: Rear shock mount on Winnebago ! Oh !!
Well what a job !! The rear left bracket has come adrift off the top chassis . It's pulled and snapped the rivets on top and due course snapped the bracket on the lower single fivet !! Pain to get to . Can't belt the rivets out . Lucky to get one rivet out . After 6 hours of trying to remove the other rivet . I asked Mrs nicley to go buy a set of drills, punch and some 10 X 40 mm high tension bolts with washers etc .. I ended up bolting bracket back and drilling out rivet through bracket as a guide for drill .. It's great having the drill shrapnel fulling on your face . At least it's drilling the bloody rivet out .. Good one GM thanks a lot !! On Monday I'll go get bottom bracket welded back on .. I'm not home . I'm on my way around Aus left Penrith two weeks ago .. Seems the riverts have been failing for some time ? Going by light rust behind them ., Oh what a mission putting the gas charged Bilstein shocks back in too . I had to tie then down 30mm to fit . I couldn't pull them in, in place as outside shroud is plastic and pulls away .. Ahh !! All done ., With basis tools too . AEG 18v battery drill set and angle grinder, socket set ., I'll sleep well tonight ..
Good job AK,,, sometimes we just "have to do it eh". Great being self reliant eh!
Well done Graeme, a very tough fix while on the road. You proved the saying "When the going gets tough the tough get going". nod.gif
Aussie Paul. smile
Hi Aus-kiwi,
You earned a six pack +.
Jim
Thing is the fresh water tank is over the ( permission to swear ? ) rivets and top of chassis rail so access wasn't easy !! Lucky the. Hydraulic stability / leveller hacks help in lifting . Miss my workshop at home .. Since loosing weight one thing I notice big time ... Rocks through tarp hurt bloody big time digging into ribs !! Skinny people's problems !! Lol
All fixed . Called into South Coast Caravan Storage at Pt Elliot welded up bracket . All good ., www.southcoastcaravanstorage.com.au
