Post Info TOPIC: Solar From Caravan to Tug
I am hoping for some much needed help on this one please and I will try to outline what is and what is & needed.
What is
Caravan - 5 x 80W solar panels charging 3 x 100Ah batteries - charger/regulator is an inbuilt 40amp unit doing 2 jobs, charging van from solar unplugged from 240v and charging van from 240V when plugged in - Auto is charging van from 240V when ever connected.
Vehicle - Has a dual battery system using a Redarc DC-DC unit (non solar) - Cranking battery and Auxiliary Battery
What is needed
Free camping and no 240V available I want to be able to put charge into the vehicles batteries from the caravans solar system
I have an Anderson plug set up at the rear of the vehicle that runs to the main cranking battery via a 40amp circuit breaker.
(There is a second Anderson plug at the rear soley set up to run the caravan fridge on 12v while travelling - this cannot be used as it is ignition regulated via a relay)
Could I just run a lead off one of the caravan batteries and connect to the Anderson pug at the rear of the vehicle so it can perform the task similar to below?
When parked at home I just connect the battery charger to the main cranking battery via the Anderson plug, when the cranking battery is full it then automatically switches over and starts charging the auxiliary battery via the Redarc DC-DC unit until full then goes on float.
Why needed
We run either one or two 12v portable fridges in the vehicle 24/7 and looking at being able to use the solar from the caravan to top up auxiliary battery in vehicle while stationary.
Any assistance is always greatly appreciated
Vince
Cheers from Vince
VK2FBUZ
I don't see why that couldn't be done but, to simplify things, why not just run the fridges from the van solar charged batteries from which the power you have should be ample.
I have fitted a solar panel to the roof of my ute canopy to charge the fridge battery in my tub.
Cheers Neil
Neil & Lynne
Pinjarra
Western Australia
Cheers Neil
 That would be a simple way only the fridges in my vehicle are hard wired in, it just seems logical to power their source in my case.
I could get a separate portable folding solar panel and plug that in but with all the solar on the van I thought tapping into that will save buying and carrying the extra.
Thanks Neil
Vince
Cheers from Vince
VK2FBUZ
Your problem will be the voltage drop due to the distance from the solar source back to the tug batteries.
You will need either BIG cables and/or a DC-DC charger at the tug end, but that will waste power.
I can charge my crank battery from the solar on the OKA via a 2 way VSR near the crank battery, but the cables are VERY big and that is difficult with a caravan/tug.
Maybe run a new heavy cable and park in the closest position possible to keep the cable as short as possible?
The way I do it isn't automatic, but it works for me:
In the vehicle
I have dual batteries in the vehicle charged via a Redarc SBI (Smart Battery Isolator)
I have 6B&S twin from the vehicles Auxiliary Battery back to an Anderson Plug on the rear of the vehicle to:
- a. Run the fridge
- b. Supply the DC-DC charger in the van for charging the van batteries while driving.
I also have another Anderson Plug at the front of the vehicle under the bonnet for running 12V accessories, also connected by 6B&S twin to the Auxilliary Battery.
In the van
2 X 105AH Deep Cycle batteries, Electroblock DC-DC and 240V charger (internally selected), 2 X 140W solar panels and Solar Controller
6B&S from the Anderson Plug at the tow hitch to a set of posts close to the battery compartment inside the van.
8B&S cable from the posts to the fridge via an ignition controlled relay.
8B&S cable from the posts to the DC-DC van battery charger.
6mm² from the DC-DC van charger to the batteries.
6mm² from the Solar Controller to the batteries via a 50A Anderson Plug pair.
When I need to use the solar to charge the vehicle batteries, I disconnect the Anderson plug from the solar regulator to the batteries, and using a 6B&S extension lead of about 3M, connect it to the front Anderson Plug on the vehicle.
Because the front Anderson plug is only connected to vehicle Aux Battery, I also need to press the "Start Assist Button" connected to the Redarc SBI which momentarily connects both Cranking and Aux batteries together, they will then stay connected while the input voltage (from the solar regulator) is above 12.7V
A 2 way SBI would overcome this extra step, but I fitted the one I have before the 2 way SBI was available.
This is not the ideal way to charge the batteries, because the solar reg is set up for deep cycle AGM batteries and the vehicle batteries are the flooded type. But because this is a very rare situation, and factoring a bit of voltage drop in the cables, I don't think it's that much of a worry.
Thank you for replies
03 Troopy I will copy what you have done as it seems what I was thinking of doing in the first place, but had to ask the question as written to see what responses came back.
again thanks for the responses
Vince
Cheers from Vince
VK2FBUZ
smilehi Troopy my enquiry regarding your setup is your electro block dc dc just what is it - is it also solar regulator, and you mentioned your solar regulator what size is it. Your electro block dc dc is that in support of your solar regulator charging via 240 and solar
By the way it's Trevor not Pamela writing this.
We have 240w solar panels and 3 batteries deep cycle 105 amp hours that work ok in the tropics, however we are wanting to do the loop and think we need more power via another panel so will need to upgrade the 20a regulator (redarc) thinking about the DC Dc 40A We also want to charge back into the landcruiser auxillary battery so that we can keep a waco fridge going when needed.
Any thoughts would be appreciated. I have an Anderson plug on the back of the l/c to operate the boat loader but don't know its rating in amps we assume it's heavy as it handles the winch ok.
Thanks
Trevorbiggrin
Trevor & Pamela
