Post Info TOPIC: Charging house batteries from the tug....
RE: Charging house batteries from the tug....
Paul, you can run your solar through your supercheap (Ridge Ryder) DC to DC charger, BUT make sure you use a relay on the solar feed so it gets disconnected when the vehicle ignition is turned on.
Cheers, Steve.
"Any day above ground is a good day... unless you're a spelunker  :)"
I want to be able connect the portable solar panel via the Anderson plug that connects to the tug.
Aussie Paul. smile
Aussie Paul. smile
 And me, but certainly not at the same time as I have not yet got around to making up an Anderson plug double adaptor. Lol
I had a thought but it got run over as it crossed my mind.
In that case Paul you can't have the tug and solar connected at the same time, so go ahead and use your solar through your DC to DC via Anderson plug smile
Cheers, Steve.
Right, that is what I thought. Now, when connecting portable solar to the DC to DC  charger via the Anderson plug it does not activate the DC to DC  charger. The DC to DC  charge specs say input voltage 12.8 to 16 volts.
Awaiting info when I get up in the morning.biggrin
Aussie Paul. smile
-- Edited by aussie_paul on Tuesday 8th of September 2015 10:44:06 PM
Hi Paul
I did not know that you can connect a solar panel to a normal DC-DC charger
Do you have the MATSON 20AMP DC CHARGER SOLAR INPUT ??
They are 3 different ones
a 10 amp DC-DC Matson
a 20 amp DC-DC Ridge Ryder from Super Cheap
and the 20 amp with solar input DC-DC from Matson
Cheers John
-- Edited by Cruising Cruze on Tuesday 8th of September 2015 11:22:32 PM
No John, Paul has the Ridge Ryder that has no dedicated solar input, but because he will only have either the tug or solar connected at any time it should still work fine as the charger can't tell the difference, it can only sense the input voltage.
Paul, how much sun did you have on the panel at the time? It will need to put more than 12.8v into the input of the charger for it to turn on and it needs 13.4v before it will start charging your van batts. Hook it up and puta meter across the input and see what you've got.
Cheers, Steve.
 If what you say is correct then why did Redarc re-engineer their DC-DC chargers to work on solar using the same input  (and not use a second input like the D250S?) I think you should do some more REAL research and give us the REAL facts. I listed the DC-DC chargers that I know will work as solar regulators a page or two back.
Peter, I'm not interested in one of your pissing contests mate.
Paul, I just went and bought the exact same charger you have as I needed one anyway so I can charge my AGM house batts from the alternator in my bus. The reason the charger isn't switching on is probably because the input voltage coming straight out of your solar panel is too high. There's a way around that though by putting a diode or 2 between the panel and the charger input. I won't be using mine with solar but I'll hook it up the way you're wanting to and test it and let you know how what you'll need.
Cheers, Steve.
Steve, diodes will not work. Try again and find out the real reason you can't drive DC-DC chargers with solar panels.
Paul, I'm ordering some diodes and should have them in a couple of days. The place I buy components from is crazy cheap so once I've got it sorted I'll get your address and post some to you. We just need to drop the voltage down a bit so the charger will start.
Cheers, Steve.
I'm still in the same boat and still following the various answers to questions asked by Paul.
Considering it's a portable panel being plugged in, and the voltage is supposedly too high for the DC to DC charger to do its job, will it work if you leave the existing regulator on the panel intact.
Or will that stuff up the function of the solar panel regulator if it is plugged into the DC To DC charger?
I seriously think I will need to forget about using the same cable and plug as used to plug in the tug to the van while driving, and run an additional cable from the van battery just for the portable solar panel.
This is becoming just to damn complicated. :(
Tom, if you have a solar controller at your disposal then the best thing to do is to have a separate cable and plug for your panel. You could try plugging the controller into the DC to DC charger, it can't hurt anything, but I doubt that it'll work and if it does it won't be as efficient.
As far as I know Paul doesn't have a spare solar controller, just the Ridge Ryder 20 amp DC to DC charger, which is why I'm suggesting he use diodes to drop the input voltage. It's not as efficient as using a separate solar controller but it will work, he'll just lose a few watts.
Cheers, Steve.
Thank Steve,
I will do that as for me it's obviously the simplest and most efficient way out to keep the two separate. I was just trying to avoid a little bit of extra work by using the same cable. Lol
Tom
Wow the things we still learn
Just a pleasure reading this topic
Thanks for all of you involved in this topic
Cheers John
Thanks everyone, I thought that the higher voltage from the panel might be the case. I do have a spare solar controller, the one that actually came mounted on the portable panels. We are hoping to get away tomorrow for the Dandenong, Yarra Valley area for 10 days. Eril wants to do the Spring gardening thing!!
I also have several largish diodes as well. The van changes from last trip are the 200 watt solar panel along with the DC to DC charger and much heavier wiring. So, I will take the controller and diodes and have a bit of a play with them.
Aussie Paul. smile
Nice one Paul, the Yarra should be pretty this time of year... still pretty cool too so don't forget your woollies smile
With the diodes, just keep putting more in series until you get the charger to kick in. Hopefully they're silicon diodes which will give about .7v drop each so you shouldn't need any more than 3. They shouldn't get too warm as they'll only be dissipating about 20 watts in total.
Ideally though, since you do have a solar controller after all, set some time aside to run a lead in and use that as it will be more efficient.
Cheers, Steve.
I tried 1, 2,and 3 diodes and now it has the DC DC charger cutting in and out. I also connected the 10 amp controller output to the DC DC charger and the same thing happens. Now I have the output of the portable panel 10 amp MPPT solar charger straight to the battery. I think I will forget about using the DC DC charger to take advantage of the portable solar. Time to get a 30 amp mppt solar charger and have an extra Anderson plug that I can use for the portable when needed.
When I get home I will add the videos of what the 10 watt MPPT, the diodes and the DC DC charger.
Trying to make less work and utilise what I have is not gonna cut the mustard it seems!!!no
Aussie Paul. smile
-- Edited by aussie_paul on Sunday 13th of September 2015 03:23:39 PM
Hi Paul
It's a pity that it didn't work out for you mate
Jaan put me on to a new ( for me ) MPPT charger
It seems to work very well for me
www.ebay.com.au/itm/40A-MPPT-Solar-Charge-Controller-Regulator-TRACER-MAX-PV-100V-INPUT-W-Meter-MT-5-/121067529663
Cheers John
If the DC to DC charger is cutting out then I'd say your diodes aren't rated for enough current Paul. I've ordered some of these (https://au.rs-online.com/web/p/rectifier-schottky-diodes/4854312/?searchTerm=BYV32E-100&relevancy-data=636F3D3226696E3D4931384E4B6E6F776E41734D504E266C753D656E266D6D3D6D61746368616C6C7061727469616C26706D3D5E5B5C707B4C7D5C707B4E647D2D2C2F255C2E5D2B2426706F3D313326736E3D592673743D4D414E5F504152545F4E554D4245522677633D424F5448267573743D4259563332452D31303026) which should be up to the task.
But since you have a solar controller that's still the most efficient way to go.
Cheers, Steve.
Would this be suitable as a mains charger for my two 120 a/h house batteries?
http://www.ebay.com.au/itm/NEW-12V-Battery-Charger-40-Amp12V-240V-40A-ATV-Boat-4WD-Caravan-Motorcycle-/360680228173?hash=item53fa37854d
Aussie Paul. smile
-- Edited by aussie_paul on Tuesday 22nd of September 2015 05:51:42 PM
Sounds too cheap for a 40 amp to be any good to me Paul, batteries are expensive so I'd spend more and get a name brand charger that is at least a 5 stage or even better, a 7 stage like this:
http://www.ebay.com.au/itm/221312655832?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Cheers, Steve.
 Thanks Steve.
Aussie Paul. smile
No worries Paul, I googled Mishto chargers and the only review I could find was for the 20 amp version and it wasn't good, the guy said it kept blowing the fuse in his house when he plugged it in.
I got those 20 amp diodes from RS Components a few days ago and my new 160w folding solar panel just arrived this morning, and I have my Ridge Ryder DC to DC charger set up in the bus. Now I have everything I need to try out my solution for your original post. I'll hook it all up and let you know how it goes  smile
Cheers, Steve.
@ Paul & Steve
I've got as well one from Bitdeal  the $80 12 volt battery Charger
It seems to work ok to me
did had no problems with it so far
Cheers John
-- Edited by Cruising Cruze on Wednesday 23rd of September 2015 12:12:24 PM
Bought these, one for battery input and one for output. biggrin
Aussie Paul. smile
http://www.ebay.com.au/itm/271987623991?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Do they come with the shunts Paul?
Cheers, Steve.
Aussie Paul. smile
Just ask the seller if they need shunts or not. I don't think the Smiths 30-0-30 needs one, just google them and make sure though if the seller can't help.
Cheers, Steve.
Ta Steve. I reckon I put one of those Smith ones in my 1969 Mazda 1200 Coupe...
Aussie Paul. smile
«First  <  1 2 3 4  >  Last»  | Page of 4  sorted by
