Post Info TOPIC: Ipad air gps systems??
I have an Ipad air with cellular. How do I get it to use the GPS satellite system rather than the phone tower triangulation system?
Aussie Paul. smile
As far I can remember you have to disconnect the Wifi connection if you want to use the GPS. If you google Ipad Air Gps you should get the right info. Anytime I have a issue I just google it.
On the road full time and loving it.
Aussie Paul. smile
 Hi Paul, yeah disconnect the wifi and the hotspot. GPS will kick in as soon as you boot wiki or any other app that needs location. Hope you are well mate
That's a bit stupid of Apple... I have a Windows phone and a Windows Surface Pro tablet and if you have GPS, it gets used whether wifi is on or not. I used to use Android stuff and it's the same. No idea why crapple would do that... doesn't make any sense to me... good to know though.
Cheers, Steve.
"Any day above ground is a good day... unless you're a spelunker  :)"
My iPad Air is wifi only and it works with wiki without turning the wifi off.
Lance C
But you don't get moving map or location do you Lance?
 I am the same with Google Dave, BUT this topic is quite confusing.
Aussie Paul. smile
 When I  go into wiki camps and use it as a GPS it is the same as using my Tom Tom it tells you where to turn and the name of the street you have to turn at.
Lance C
I use an iPad and iPhone with some mapping apps.
Just turn the GPS on and it will use that, moving map and all.
Don't need to turn anything off.
Lance C
 OK, I don't own any I things, but I was under the impression that the Ipad Air with wifi only doesn't have a GPS because the GPS chip is part of the G3 module, and uses the same antenna. So, without a GPS chip you will only get location information via wifi, which will only work if you are connected to a wifi network.
Is this the case, or do the wifi only models also have a GPS chip?
My Android tablet (Asus Transformer 101) does have a GPS chip, so you do get location directly from GPS satellites.
03_Troopy wrote:
Lance C
 Correction from what I told you before 03Troopy,I tested mine today ,you must have WIFI to set the GPS in motion,first up a ladies voice tells you what direction to start at then there is a map of your route hi lighted in blue just follow the map to your destination, but you need WIFI to set up first ,then it works without the WIFI, I tried setting up at the opposite end to come home no WIFI wouldn't set up for me .hope you can make sense of my jumble.
Lance C
Olley46 wrote:
03_Troopy wrote:
Lance C
Lance C
 Looking at the specs, wifi only doesn't have GPS, so any turn by turn direction you have will only be available when connected to a wifi network, unless it is giving an approximation derrived from it's 3 axis gyro, accelerometer, and digital compass all combined.
Location
  • Wi-Fi only
  • Wi-Fi
  • Digital compass
  • Wi-Fi + Cellular
    Wi-Fi
  • Digital compass
  • Assisted GPS and GLONASS
  • Cellular
-- Edited by 03_Troopy on Wednesday 13th of May 2015 07:01:48 PM
Thanks everyone, I have learnt a lot about my Ipad air with cellular over the last couple of days. My cousin KJB told me about a gps system that he used in Europe and in the US I think. I downloaded the 7 day free trial to test it while away this week.
Got to Yarrawonga mid arvo today after spending last night at the Longwood recreation reserve, approx. 17km south west of Euroa.
Aussie Paul. smile
https://copilotgps.com/uk/personal/android.asp
Which mapping app did you download Paul?
 The one in my previous link, CoPilot. I used the Ipad one of course.
Aussie Paul. smile
OOps, I must be blind, I didn't even see the link.
 Ha ha, obviously I am not on my own with " looking but not seeing"!!!!!!!!!!!!!! biggrin
Aussie Paul. smile
