Post Info TOPIC: Folding Solar Panels
Hi Guys,
Has any one bought a folding solar kit with out a regulator or cables and only a junction box on each panel i am having trouble buying a kit,
any help would be welcome.
Thanks      John.
Jaycar have comprehensive cables and equipment for folding solar panels...I purchased additional cables with Anderson plugs to be able to set the panels a fair distance from my Van....I would try Jaycar and they are usually reasonable in their prices and have staff with a bit of knowledge of their products...good luck..Hoo Roo
'Without Going, You Get No Where'.
' Aspire to Inspire before you Expire'
 Where Gold be....is where Gold be......old Cornish saying......
The older we get the fewer things seem worth waiting in line for.......
Put "solar panel regulator" into the EBAY search engine and you'll find hundreds of regulators - refine the search to Australian sellers. I bought one for under $20 for my 80watt folding panels and it has given no trouble in the last 3 years. You can spend big dollars but they all do much the same job.
This is the type I bought:
www.ebay.com.au/itm/15A-Solar-Regulator-Controller-12V-24VDC-Solar-Panel-Charge-battery-180W-360W-AU-/140926289474
Most folding solar panels come with a regulator. I blew up my first regulator and set up another inside the vehicle myself. I have cut off the joiners supplied with my panels and soldered Anderson plugs on them and made a longer extention lead with Andersons on it. I think a 10 meter lead is sufficient but a 5 too short. It's very easy to do.
Janette
If I have been taught correctly by members of this forum you want the solar regulator as close to the battery as possible. I have folding panels that have the regulator mounted on the back of one of the panels. I will remove that regulator and run the solar wires directly to the solar regulator that I have close to the battery that is fed by the roof mounted solar panel.
Aussie Paul. smile
Just buy two solar panels and a pair of hinges and hey presto you have what you want, no regulator
Alan
