Post Info TOPIC: Drill powered water pump
Does anyone have one they recommend? Aldi had them recently but I missed the boat. It's just to transfer water to the tanks, rather than lifting and pouring.
thanks,
MJ
Not sure what they are actually called but have you thought of a shaker syphon hose? It's a rubber hose with a brass fitting one end with a ball bearing inside, you shake it up and down in the water an it starts to syphon out the other end. No need for a drill then.
Just a thought.
Thanks Doug, but I'll have the drill on board anyway biggrinbiggrin
Syphon will only run it down hill..
Aussie Paul. smile
Maybe not on north of the equator
One of my sons bought this pump off ebay - uses it to pump out his tinny and reckons it pumps good - has the push on connectors.. Cost just over $20.
http://www.ebay.com.au/itm/DRILL-POWERED-PUMP-FROM-MEDALIST-1-8-CUBIC-METRES-PER-HOUR-/201020188347?pt=AU_Hand_Tools&hash=item2ecdbca6bb&_uhb=1
I think this is the one you are talking about ,this is from Aldi,s as of yet I haven't tried it out.
Use an old washing machine water pump. Pick up from road side.
Larry
Dougwe
I have similar to one of those but I shake it after the water has transferred!!!!!
Doctor has given me tablets and I should be right
Regards. Brian
bab600 wrote:
Dougwe
Regards. Brian
 thats a great answer love itbiggrinbiggrin
Dave S
iv'e lost my glass.
I have a shurflo water pump that I will be putting under the van close to the water inlet and pump from drums to the filler
saves the back
Ken
DUN WURKUN
Thanks Denis for the link, that's all I need. And yes Lance, it was seeing the Aldi catalogue that gave me the idea, but I forgot to go buy it, doh!
And Ken fitting a pump underneath is a great idea but beyond my simple skills so a portable pump will be peachy for me.
Also, I found Bunnings sell one..... www.bunnings.com.au/gfb-6mm-drill-powered-pump_p6321494
My question is, they state electric drill. Will a cordless be able to run it? My logic says it will, but I really wouldn't have a clue, TBH!!
I see no reason why you couldn't use a cordless drill. Just have a second battery charged and on standby as the battery will discharge resonably quicky.
Be a bit careful. Bought a few over my time and found its critical to follow the instructions on recommended rev rate. Battery drills usually spin a lot slower than electric drill, the rev rate is always printed on the drillthe way. If you run them to fast say goodby to it.
Chicken strangler
ralph.
Tryed the Aldi,s water pump today with my cordless drill a no go ,hooked up the electric drill and away she went,so it might have to be a very strong cordless drill to run it .
Lance C
Thanks for that Lance. I've done some research and can't find a cordless operated one. Seems a 12v bilge pump is the go, but for me a cordless drill would be easier. Back to the drawing board.
I use an electric shower pump I bought from Ray's - it's submersible and just plugs into one of those cigarette lighter sockets, works a treat. www.raysoutdoors.com.au/online-store/products/Wild-Country-Camp-Shower-12V.aspx
Dave
See you on the road
 I have got this bilge pump fitted to a portable shower head,it pumps 360gallons an hour it is American,I run it of a jump starter or the cigy lighter in the 4wd,I payed about $30.00 for it a long time ago,great for just a water pump,it is submercable  great little pump bought it from a boat dealer.
-- Edited by Olley46 on Saturday 13th of September 2014 11:24:57 AM
Thanks, the bilge pump looks good, but will it fit into the water container?
I thought of this... (One with removable shower head) but it's getting the pump into the water container neck. I'm beginning to think good old fashioned syphoning could be the go (that's how I empty my spa, cos the drain pump,doesn't work!!!!)
