SmartBar Floriade Darwin International Film Festival Goodlife RV Resorts Celtic Fest
Post Info TOPIC: Coming to Perth??
Coming to Perth??
Hi, I have just posted on
general forum offering free accom for GN's. If you are in or are planning to be in Perth you may be interested.
I believe that this is a good thing you are doing.. On behalf of.. Thank you
  I always leave my camping area cleaner than I found it.
Thanks Jimbo. I live about eleventeen seconds off GE H'way. I don't need a lot of help,more moral support. I am in the process of coming off medication which has had awful side effects. Once Im given the all clear I can take off and do little trips leading to bigger trips.
I'm tied up in Perth right now. I'm at a van park while I sort my stuff out on "Betty".
Do you have room and a power point for this thing I'm driving? Height is more the problem than size, as in length and width. PM me if you want an understanding Cruising Granny as a drive-way guest.
Transport has no borders.
Hi CG, I'm sure there's room. Where abouts are you in Perth?  If you'd like to call in and check it out for yourself you're more than welcome. The only thing that might be a problem is the height, but that's only if you wanted to use the shed. Maybe hear from your soon.
smile
-- Edited by Colls on Thursday 1st of August 2013 01:44:40 PM
Duh
Hi Colls,
Suggest you edit and delete the address and contact details and send the info to CG by PM, safer option, also prevents spammers etc.
-- Edited by Duh on Thursday 1st of August 2013 02:15:11 PM
Thanks Vic. All done.
