SmartBar Floriade Darwin International Film Festival Goodlife RV Resorts Celtic Fest
Post Info TOPIC: slide on campers
slide on campers
i know  i talk of the big tardis styled motor home but i keep going back
to the idea of the slide on for me as  a solo, if and when it happens,
been wondering how hard it is to take one of and on the back of the ute
and i know each set up is different , and found this video, aussie too!
in case video don't work click the link...
http://www.youtube.com/watch?v=B5kUqkpU9-0
-- Edited by milo on Friday 19th of July 2013 05:21:36 PM
The Drewsterz my band site
Milo Online  my personal site
Yes, but howmuch do they cost? I will buy one , when I win looto. Till then,Iwill stick to the Old Freeway. Nice rig, tho. Bill
being a solo as well the slide on suits me perfectly
The hardest bit of loading up is getting the ute underneath square without a guide to help.
you think it is straight until you get out and look..........crooked.............try again
after that mine has 4 turnbuckle tie downs to connect and plug in the power then away.....
takes me probably 30 minutes to load with a bit of squaring up and 10-15 minutes to unload
i operate the legs with a 18volt cordless drill................i thought the $2000 option of remote control power legs could pay for a hell of a lot of diesel
happy Travels :-)
http://livingthedreaminoz.blogspot.com.au
Baz
I worry about the height and size of that camper. I love the concept though and they look like a really nice unit.
Janette
Made clickable for Solo Nomad.
http://livingthedreaminoz.blogspot.com.au/
 thanks
 i need to learn how to do that haha
happy Travels :-)
Baz
think I'd stick to the mazda or toyotas, great find sheba
Mine's similar (Freeway/Courier combo like Bill12 has). But I have 2 more turnbuckles with chains attached to the tray uprights, and two bolted "stoppers" at the rear to inhibit any rearward movement. As to center of gravity, it's like a yacht with a keel to counteract the mast. Now that my storage bins at floor level are loaded with batteries, ladders, tools and other equipment the stability has improved dramatically. The water tank is at floor level as well, across the width of the camper just behind the truck cab. Nothing heavy is stored above the waist line. It's basically all shell up there. Unloading is pretty straight forward, but loading is best done with the help of a second person who can guide the driver.
I'm happy with my slide-on. Plenty of room, especially for a solo, no towing, and heaps of storage.
Oh yeah... and a roof strong enough to hold a couple of solar panels.
-- Edited by GaryKelly on Saturday 20th of July 2013 12:49:55 PM
Gary
 Would cost a lot more dollars than i have.
the one i looked at was $10,000 and a poky thing.    Put me off slide-ons
I am currently thinking ute and caravan
Dawa
dawa dente
I also love the idea of slide ons. BUT....I really am put off by the overall height/ centre of gravity. Had I been able to find a pop top at the time I was searching. that would have been my choice, as a solo traveller. However, to each his own
Take only your memories, leave only your footprints
how do you go for height Gary ?
In stilettos or flatties, Milo? Or do you mean the camper? Mine is about a foot taller than normal because it sits on a box divided into 3 lengthwise compartments for storing camper jacks (legs), poles, camp furniture and other things. I really like that extra storage. So it's a bit over 7 feet above tray height, making it about 10 feet (3 meters) tall from ground level. It looks a bit ungainly but it's fine, and really no taller than many motorhomes. I don't wizz around corners or do silly things, and I keep it under 60km/h up the drive hehe. Admittedly it took a little getting used to after driving the truck empty for a long time but it's fine now. Bill12 suggested Ironman helper springs which I've had installed. Quite cheap and very effective.
Gary
i was wondering if they were as high as a normal motor home, ie the ones with bed over cabs...
Mines 2.7 m high, andif you keepyour wits about you , you have little trouble.Very comfortable, andyou don,t have a pop top toworry about. The Ironman load plus helper springs solve the stability problem and are great at $120. I fitted mine,but anybody with some mechanical aptitude can do it .A styleside ute or a 2wd table top would easier to load the camper than my 4wd, Which is a bit high.I get 7 or 8 klms to the ltr at 90 to 100 kph from my 2.5 courier diesel loaded.Good combination. Bill
Yep, roughly the same height as those cab-over motorhomes, Milo.
Gary
frackenfurter.jpgAll Gary need s now is a few of those streamers, like Priscilla, Queen of the slide ons.That would make a good photo.Don,t forget the stilletos or flatties, Gary.You might look a bit like Frankenfurter,from the Rocky horrow show!..............Bill
-- Edited by bill12 on Sunday 21st of July 2013 03:35:40 PM
-- Edited by bill12 on Sunday 21st of July 2013 03:38:44 PM
 My craft stuff takes up room so with a slide on I would need to tow a trailer for my spinning wheel etc.
Also camp cook ware
Dawa
dawa dente
Good morning all - I have a slide on camper- mine is an Active Camper. They are made north of Coffs Harbour - a family owned business - great people to deal with. I find when I go travelling on my own I have no problem at all with setting up or packing up - it is so easy. There is a website for them which shows the whole concept. They are not very high when closed up so there doesn't seem to be much wind drag. I have mine on a Hilux. Happy camping - Nelly (stilettos or flatties Gary!!! mmmmm!!)
Where there is a will there is a way!!
 DID have suspicions  about Gary........hmmmmmmm
Dawa
dawa dente
Also camp cook ware
Dawa
 Ve have com fur your spinning veel,
Hans, destroy the spinning veel!
Ohhh Monti Python love ya.
Cheers Peter and Sue
Now where the hell did I park my camper?
Gary
bill12 wrote:
All Gary need s now is a few of those streamers, like Priscilla, Queen of the slide ons.That would make a good photo.Don,t forget the stilletos or flatties, Gary..............Bill
 fish net tights?
dawa dente
and suspenders do you think - don't know about that!!!
And there I was thinking my reference to stilettos and flatties had gone unnoticed.
Gary
It is funny how this started out as a slide-on post and ended up talking about Gary's stilettos and flatties!! Is it all tied in do you think?
confuseWho is tied up? lol
 Not a snowball's chance    LOL
Dawa
dawa dente
Tied in Bent Axle Bob not tied up. lol
struth!!confuse
Hey Milo did you have more questions about a slide on camper? I think the original post went a bit haywire!!
