Post Info TOPIC: Location of water tank bung
Being a female, new to this area and need to clean out the water tank. Pse help, dont no where to locate the bung to flush out water on our freedom jayco. Thanks in anticipation!
dibbers
Usually at one end of the tank dibbers maybe at the outer end. I stand corrected though.
most dont have a drain bung, just undo the lowest hose.
blaze
A van or motorhome? My van has a bung to undo on the tank.
Duh
Should have a bung like Doug said somewhere around the bottom of the tank underneath, if a used van it may have been replaced by a tap.
I have also had one like blaze said where there was none and I had to undo the clip on the hose which attaches to the tank and drain it that way.
