Post Info TOPIC: How To Give A Cat A Pill
1. Pick up cat and cradle it in the crook of your left arm as if
holding a baby. Position right forefinger and thumb on either
side of cat's mouth and gently apply pressure to cheeks while
holding pill in right hand. As cat opens mouth, pop pill into
mouth. Allow cat to close mouth and swallow.
2. Retrieve pill from floor and cat from behind sofa. Cradle cat in
left arm and repeat process.
3. Retrieve cat from bedroom, and throw soggy pill away.
4. Take new pill from foil wrap, cradle cat in left arm, holding
rear paws tightly with left hand. Force jaws open and push pill to
back of mouth with right forefinger. Hold mouth shut for a count of
ten.
5. Retrieve pill from goldfish bowl and cat from top of wardrobe.
Call spouse from garden.
6. Kneel on floor with cat wedged firmly between knees, hold front
and rear paws. Ignore low growls emitted by cat. Get spouse to hold
head firmly with one hand while forcing wooden ruler into mouth.
Drop pill down ruler and rub cat's throat vigorously.
7. Retrieve cat from curtain rail, get another pill from foil wrap.
Make note to buy new ruler and repair curtains. Carefully sweep
shattered figurines and vases from hearth and set to one side for
gluing later.
8. Wrap cat in large towel and get spouse to lie on cat with head
just visible from below armpit. Put pill in end of drinking straw,
force mouth open with pencil and blow down drinking straw.
9. Check label to make sure pill not harmful to humans, drink 1
beer to take taste away. Apply Band-Aid to spouse's forearm and
remove blood from carpet with cold water and soap.
10 Retrieve cat from neighbor's shed. Get another pill. Open
another beer. Place cat in cupboard, and close door on neck, leave
head showing. Force mouth open with dessert spoon. Flick pill down
throat with elastic band.
11. Fetch screwdriver from garage and put cupboard door back on
hinges. Drink beer. Fetch bottle of scotch. Pour shot, drink. Apply
cold compress to cheek and check records for date of last tetanus
shot. Apply whiskey compress to cheek to disinfect. Toss back
another shot. Throw Tee shirt away and fetch new one from
bedroom.
12. Call fire department to retrieve the damn cat from across the
road. Apologize to neighbor who crashed into fence while swerving
to avoid cat. Take last pill from foil wrap
13. Tie the little bastard's front paws to rear paws with garden
twine and bind tightly to leg of dining table, find heavy-duty
pruning gloves from shed. Push pill into mouth followed by large
piece of filet steak. Be rough about it. Hold head vertically and
pour 2 pints of water down throat to wash pill down.
14. Consume remainder of scotch. Get spouse to drive you to the
emergency room, sit quietly while doctor stitches fingers and
forearm and removes pill remnants from right eye . Call furniture
shop on way home to order new table.
15. Arrange for RSPCA to collect mutant cat from hell and call
local pet shop to see if they have any hamsters.
How To Give A Dog A Pill
1. Wrap it in bacon.
2. Toss it in the air.
The Master
That is so funny, so good. I will have to save that one, if you don't mind.
Happy Wanderer
Don't worry, Be Happy!
That is so funny...and so very true!!
biggrin biggrin biggrin biggrin
 Cheers. Pam.
Safe and happy travels everyone.
Or place pill in vanilla icecream and allow cat to gently lick it off your hand.....
 Cheers, Chris...
The only way I ever gave a cat a pill was with a .22
