Post Info TOPIC: 2000km 21 days
2000km 21 days
 Greetings and Salutations,excited  Earthlings,Nomads,B.Boomers, and un-excited people.Tomorrow we get to  Ceduna,after 21 days,2000km Mr Excitment, John will b going to Perth , I will b heading east to Victoria, im so excited for Westen Australia, the IQ rate there will b in melt down when John crosses the State line,,,,,,hehehe.....Billeeeee...
Simple is
       Beautiful
The Master
I see Mr Excitment has put his solar panels in the well above the cabin area. How has he sucured them down?
Happy Wanderer
Don't worry, Be Happy!
 Howdyeeeeee Happy,,,,U excited,,???,, did U give Him a clap,,??heheheh,, when He gets into His Van , has a big screw near his head , holding the panels down.......Billeeeeee..
Simple is
       Beautiful
bb I found silastic will do the job,you try and get them off.(there's that beee again)
Always on the Road.
Oh we nomads are so resourceful. Between us all with our individual skills, we could build a van or vehicle that would never lead, it would have every useful piece of equipment, and would be soooooo comfortable we'd never want to get out of it.
Congratulations and job well done John.
Now Billeeee, are you going into PR when you get home? Are you on commission or is it a "love" job?
As for the distance, when I went from Broome to Nowra and back again to take delivery of this van, I did around Oz in 25 days.
Transport has no borders.
         Bugger................
Simple is
       Beautiful
The Happy Helper
For John -clap.gifclap.gifclap.gifclap.gifclap.gifclap.gifclap.gifclap.gifclap.gifclap.gifclap.gifclap.gifclap.gifclap.gifclap.gif
For Billeeeeee - cake.gifcake.gifcake.gif - you take the cakewink
jules
(Ben, aged 10)
Hi Marj,
Having been off line for a couple of days I see that Billeeee has spilt the beans on how I fixed the solar panels.
What actually happened was that I bought 2mtrs of 50X50X2 aluminium angle cut it in half and riveted the front angle to the recess allowing for the return to hold down the front of the panels. The back angle was riveted to allow the back of the panels to fit in snugly and then was riveted to the panel.
I had some foam rubber the helped to secure the front without movement and the back angle had to be cut in a vee to allow for the curve of the roof. I then drilled through the roof in the rear corner and drilled up from the cabin and fished around with a piece of cable until I was able to catch it and secure the solar panel cable to it and pull it through.
The cable had to be cut to allow it to fit through the hole and I was able to cut off the surplus and refix the anderson plug then plug it into the anderson plug already mounted in the van. I had some auto body filler in the van so I was able to seal the hole securely to prevent leaking.
As you can see I am a resourceful guy who gets things done with a minimum of fuss. It was all done in the Mitre10 carpark incase anything else was needed. But all that was bought was the aluminium angle and aluminium rivets, all done for around $30.
Edited to mention that it was Billeee's idea to put the solar on the front of the roof, I always said that it would make the pop up too heavy.no
-- Edited by yeoeleven on Sunday 2nd of October 2011 06:16:18 PM
The Master
Well done, John. I was going to ask did you seal it all so you don't get any leaks. I have that same well/recess and know it can get a bit of water in it. But I see you have given me the answer there.
Hope it works well for you, will keep in mind when I finally get some solar panels.
Happy Wanderer
get some sicaflex and put over the body filler because if you dont I feel it will leak after a while
blaze
4years ago I went right around, Townsville to Townsville , via Gibb R rooad, and the Tanami track,Broome , perth , Port Lincoln , Brocken Hill , Western NSW,15000KLMS  and back in 24days, and don,t think I was racing. Then , again,my sister says I do lightning tours, and should stop and smell the roses..........
-- Edited by bill12 on Monday 3rd of October 2011 07:43:38 AM
 Sooooo bill, U a flower sniffer tooooo.,,just watch out... make sure no bees in flowers when u sniff it , bee up nose ,,,not fun,,,,stay excited bill.........Billeeeeeee
Simple is
       Beautiful
The Happy Helper
Only trouble with smelling the flowers - bees sting!!!! me no breath!!!!
jules
(Ben, aged 10)
Hey Billeeee when u heading back to Vic?
Live your life, not someone else's.
@brettsworldtour
 Finger ok, ,,up noze ,,,,not Beeeeeeee...??
Simple is
       Beautiful
The Happy Helper
winkYou are crazy!!!!!!! no need for the full moon - you keep the laughs coming - I look forward to thembiggrin
jules
(Ben, aged 10)
 Howdyeeee Brett,, u excited as I am .??/  found out where I am ,,am at Kimba ,,.. went and looked at some rocks ,, hehe got lost... stayed excited,,,hehehe,..10 out of10 for today,,,,Billeeeeee...
Simple is
       Beautiful
Ma
You're a worry Billeee.....................
Howdyeeee excited Nomads,Normal ,and no sooooo Nomal people,,, ..Was excited , another day to enjoy life, ,,Spent 3 exciting hours talking to every body,in Wirrulla,  trying to find out the secert,,,,,,was talking to a Old Granny, bout 75 lived in a old van,,,,,,She told Me.........Bileeeeeeee
Simple is
       Beautiful
 Howdyeeee excited ,B.Boomers,and un-excited people  Bugger forgot to tell U what it was, the pic tells the story...dont need to say anymore,....Billeeeeeeee.
Simple is
       Beautiful
The only thing I could think of as a Wirulla secret was the dinosaur ant. It's a very long ant, about 3-4cm, which has prehistoric beginnings.
It wouldn't take you very long to talk to "everyone" in the town. It's not a very big town, but everyone out that way has a big heart. They have to have big hearts because much of it is marginal farming country, and that's what the town's income base is.
It's also the gateway to the Gawler Ranges to the north.
Keep enjoying the journey Billeee, and sharing it with us.
Howdyeee Boomers Nomads, excited people ,forgot to tell U , the Old lady that told Me the secert ,  tossed a rock at Me ,hehehe..........Billeeeee
Simple is
       Beautiful
The Happy Helper
Did the rock hit you? Is Granny right about the secret being the big ant? Why did she toss a rock at you? And if it's not the ant - spill the beans, what's the secret?????
Your cryptic posts are intriguing!!!!!!!!!!!!!!!!!!!!!!!!!!!!
jules
(Ben, aged 10)
You weren't Sea-Duced by any chance?
Vic
I went north from Wirrulla through the salt lakes to Kingoonya, rejoining the highway just north of Glendambo. Met some Norwegians in Wirrulla they had limped into town from Kingoonya with their tyres full of grass (not that kind) that a farmer had filled for them so they could drive the rest of the way all, all 4 were blown.
I only had a 2WD van but had no problems, drove to the conditions (kept my speed down) as there were lots of sharp limestone rocks on the track.
Interesting place Kingoonya, got some fuel there but got bad vibes so didn't stay there, driving solo at the time.
Didn't know about the town secret at Wirrulla, was the Golden Palace a brothel in it's day?
-- Edited by Vic on Tuesday 18th of October 2011 06:19:16 PM
Vic
Hi Ace Pop Top Campervan & A'Van A'Lite Camper Trailer.....
Khalil Gibran says "We tarry forward - not backward".
Spread the laughter
Share the cheer
Let's be happy
While we're here.
Billeeee, we're still waiting for you to reveal the "secret". C'mon, put us out of our misery mate. Spit it out!
yes, please Billeeee spit it out!
ChiChi
 Heeey Billeeeeeee, sounds like she got a bit excited...... wink
Life is too important to be taken seriously!!!
Vic
 Maybe she was a cougar that worked at the Golden Palace at one time and Billeeeeee wouldn't pay the "going price" wink biggrin
Vic
Spread the laughter
Share the cheer
Let's be happy
While we're here.
