Post Info TOPIC: Ampfibian 10 amp to 15 amp 240 Volt Adaptor
RE: Ampfibian 10 amp to 15 amp 240 Volt Adaptor
oh now thats just not nice, it may be true but it is still not nice!!!
Just unpacked my new toy. Works well. Would recommend.
I CHANGE MY OPINIONS OFTEN
BUT NOT MY WAY OF THINKING
  Hi Popeye
Now you can safely & legally connect to a 10amp outlet
.You have shown common sense smile
That's an oxymoron.
Hi All
Some more on extension leads
AS/NZS 3199 requires. Clauses 5.1 and 5.2 requires:
5.1 General
The plug and cord extension socket shall be each of the same current
rating and configuration, and in no case greater than the current- carrying
capacity of the flexible cord.
5.2 Plug
The plug shall be a three-pin flat-pin plug complying with AS/NZS 3112,
and have a current rating of not less than 10 A.
-- Edited by oldtrack123 on Saturday 9th of January 2010 09:51:59 PM
-- Edited by oldtrack123 on Saturday 9th of January 2010 10:12:40 PM
Hi All
 This post is due to some questions that developed on another forum recently
Where the use of Clipsal & Arlec type devises were being actively promoted at caravan shows
Also a RVMMA handbook was being distributed illustrating their use
The section of the RVAMAA handbook dealing with electrical safety & in particular the use of Cipsal /Arlec type products for RCD protection &/or connection of  a 15amp plug to a 10amp socket is  NOT AN APPROVED USE
 I have made inquiries direct to the relevant authorities
To date ,I have had three replies regarding the incorrect information in the RVMMA booklet
regarding the use of portable outlet boards
WA &TAS have confirmed that "epods " complying to AS/NZS 3105 ARE NOT APPROVED FOR THAT SITUATION[ie used  for connection to a van extension lead
The Qld SEI has confirmed that the info was supplied some 10years ago,IT IS OUT OF DATE
THEY have contacted the RVMMA
Admin
This is not an attempt to revive old wounds, but to ensure safety is understood for the benifit of ALL
-- Edited by oldtrack123 on Monday 15th of August 2011 08:52:20 PM
«First  <  1 2 3 4 5 | Page of 5  sorted by
