For sale is a Capstan Winch that I built up to tow a 2 tonne caravan backwards up a long and narrow, slightly uphill driveway.
I used a 50m length of rope and a remote control for the motor. I also used a ratchet jockey wheel so that I could steer the caravan, and the ratchet would hold the van on the sloping driveway when the top rope was released.
For those unaware of how a capstan winch works, it has virtually unlimited pulling range, only limited by the length of rope available. With the motor running, you pull on the top end of a rope wound 4 or so times around the capstan. When you pull, the rope grips the capstan and the winch operates release the tension on the rope and the winching action stops but the winch keeps running with the rope slipping on the capstan. The rope must be wound around the capstan in the same direction as it drives, and there can be no knots in the rope throughout its operating length.
Motor Details: Royce Cross Group Single Phase 240V Flange Mount Induction Motor 0.37 KW / 0.5 hp 1380 rpm Capacitor Start, Capacitor Run Gearbox Details: Bonfiglioli (Italy) Ratio: 1 : 100 Capstan Details: Material: Aluminium Root Diameters: 88.5mm (fitted) and 62.5mm (spare) Pulling Speed: The pulling speed will depend upon a number of factors such as diameter of rope, load being pulled and slope of ground. As a guide, the fitted capstan will pull at approximately 4.5 metres/minute with a 16mm rope.
Price: $180
Recommend pick-up so that you can see the winch operate. PM me for any more details, arrange to see etc.
Sorry, first photo may be upside-down. I tried to remove it, but it appeared just the same.
-- Edited by glids37 on Thursday 26th of November 2026 08:45:52 AM
-- Edited by glids37 on Thursday 26th of November 2026 08:48:00 AM
