Post Info TOPIC: Ibis 3 air command roof top air conditioner not cooling
Hi All Re above air con, normal running has always been colder out of one side than the other 3. Water has always dripped from the roof like it should. Now when we run it compressor starts, we have cool air still colder on one side while the water is dripping then after a few minutes water stops dripping and air isnt as cold. After we turn it off znd turn it back on we get a lot of water run off the roof, air seems cool, still colder on one side, then water stops running again and air is only coolish. Hubby is an electrician and has tong meter measuring current and seems like compressor is running all the time taking the right current. He is not a fridgey. Any ideas. Could there be a blockage in the cooling system. TIA Jo
We had a portable home reverse cycle air conditioner. On the cooling cycle it would pump the water over the condenser to evaporate the water.
On reverse cycle it obviously couldn't do that. If the AC got too full of water the compressor would turn off. Once we emptied the AC the compressor would work again.
It could be that your AC has a sensor to detect if it swimming in condensation. This would suggest there is a blockage. Occasionally I have had to clean out our split system AC drains. A lot of crap grows in the drains.
