Post Info TOPIC: To polish & not roughen!
'Scientists are collaborative and rarely use sandpaper other than perhaps to polish their egos now and then.'
Robyn Williams, The Science Show
On the one hand you see bowlers shining the ball by rubbing it up and down their crotch, while on the other hand you have fielders roughing it up with sandpaper. I don't get it.
 One side is polished and the other side is roughened up to promote swing, the bowler will cover the ball with his hands during his run up to prevent the batter seeing which way the ball is going to swing.
I often found a ball would reverse occasionally when holding the ball ACROSS the seam, not down it for some strange reason.
The ball does not always reverse, sometimes it is just a fault in the production of that ball alone?
They do react differently under different conditions, at no time did we in our low standard of cricket ever alter the ball itself other than the normal shining process.
I recall one hot day on a flat wicket, very little wind I could see my outswinger reversing after it passed the stumps.
We had a stand in wicket keeper that day and he was back about 16 to 18 yards.
The ball was swinging away, then reversing and darting back the other way in flight and wrong footing him sometimes.
I could see him gesturing to the slips cordon every time it happened. It wasn't consistent either.
Just a fault in the pill and maybe the weather conditions.
Don't know, it was rare but happened every now and then.
It really only ever occurred when the ball was still relatively new.
Some bowlers are past masters at disguising the ball. It helps.
About the only "trick" I used to do was to wait to see if the batsmen was looking.
Then at the top of the run clearly show the two fingers set in a stock ball outswinger grip.
Then alter it as running in to across the seam and give him a bouncer aimed somewhere near the collarbone or so.
Some bowlers just grab the ball and run in and let it go.
There was that famous incident many years ago.
In game 1 of a shield season, Jeff Thomson was spraying it all over the place.
The captain, Greg Chappell walked all the way up the wicket in the middle of and over and said "What's going wrong Jeff?".
Thomson replied "How do I hold the ball again skipper?".
Race 7 at Canberra has some interesting starters in it today.
There is a trifecta or a first 4 in there somewhere.
1. Sandpaper
2. I'Mintowin
9 I've Bean Tryin'
12 Well Timed
13 Hot Bandit
I will be keeping an eye on the race with my decade old camera & two decades old lens at 67 metres distance.
Only wish I had a good camera to read months & year to let my neighbour know when their fire extinguisher needs an inspection, it may be due in October!
Ha Ha.
That "omen" trifecta in Canberra got up.
2,12,1
It paid $627.30 on Sportsbet.
I had a little bit of the action.
At least something good has come out of Sandpapergate !!!!
I'Mintowin Well Timed Sandpaper
Filled my modest little Sportsbet account up!!!!
Thanks guys for dredging that old acorn up from 8 years ago....
Makes sense.
I never knew that bowlers were favouring a particular side. I always thought they were aiming for a uniform shine, just like a new ball.
Very few quicks swing the ball each way.
That is why a "reversing" ball is handy.
Imran Khan was a past master with that skill.
Which way a bowler moves the ball is often determined by their action.
A slight round arm action will have most swinging away from the right hander.
An over the top side on action will usually benefit the in swinger to the RH.
I think it is fair to say most club bowlers swing it away?
Bob Massie did massive damage on a tour of England in the 70's with Dennis Lillee at the other end.
Massie had a big in swinger that in the right conditions could go a long way and was very dangerous.
Whereas Lillee was an outswing bowler but had a mean "off-cutter" that came back the other way by ripping the fingers across the ball at delivery.
Massie relied more on the "straight one" to get an outside edge.
Bowlers with the ability to move it both ways are very valuable and a bit rare.
That is why that sandpaper topic is what it is. If an outswinger can get one to dart back, it is a wicket ball.
Extreme quicks like Jeff Thomson and Steve Bernard rarely swung the ball as they were too quick for it to react.
Good swing bowlers like Glenn McGrath, Massie, Tangles Walker etc were all about the 130 KM mark and relied more on swing and skill.
I enjoyed cricket in primary school, but I lost interest by the time I got to high school. However, I've now been reading about the subject and there's quite a lot of science in it. I notice that baseball pitchers make the ball move around without any physical tampering, so I'm wondering just how much movement a shine can impart.
It's too bad that bowlers feel they need to intimidate batsmen by attacking their upper body and head. Strangely, that's "cricket", but underarm bowling is not. I would think that a skillful bowler would limit himself to targeting the stumps or enticing the batsman to nick the ball. It used to be like that in the old days, but something happened.
Dorian, it was bodyline- 1930's
Cheers Craig
