Post Info TOPIC: An Aldi "Handy To Have"
Hi everyone, In the current Aldi catalogue (from today 29th July) is an instrument that I wish I had in the van a few times. It is a Workzone Infrared Temperature Measurer for the cost of $20.00. It's temperature range is from -50 to +500 degrees C. It even comes with the batteries & weighs next to nothing.
Honestly save your money the temperature reading no those are so far out the buses dont run there any more. if you think you need something like that then buy quality . i suppose to be fair if you just wanted to compare temp balance say in wheel bearings or brakes they may be ok but to actually read temp then forget it
-- Edited by fatty on Wednesday 29th of July 2026 04:11:41 PM
 Fatty, be more specific please.
Are you talking about this technology in general, or the current Aldi product in particular?
An Aldi
The next sentence of my post ( which you conveniently cropped out) which reads " if you think you need something like that then buy quality" should be clear.
Hi fatty,
I agree at $20 isn't going to buy quality but for a quick reading, this is ok - previously I have used finger touch but that can get painful if one has left the handbrake on (as I have).
I've had one not so nice incident in the past with a wheel bearing seal blowing out. My wife points out "our parking spot" on the Hume Highway, near Tarcutta when we go that way. The lesson - "Never put off doing a bearing check when you have a good opportunity to do it! This should not be deferred!
Agree Warren as i said in the laswt sentence of my original post for what you are describing the Aldi, or any other budget Infrared thermometer will be just fine. as soon as you get a significant variation in one wheel you will know you have an issue. my original comment was that they are not at all accurate with the actual temperature reading and shouldnt be relied on for checking say the fridge freezer.
RE: An Aldi "Handy To Have"
Warren-Pat_01 wrote:
Hi everyone, In the current Aldi catalogue (from today 29th July) is an instrument that I wish I had in the van a few times. It is a Workzone Infrared Temperature Measurer for the cost of $20.00. Its temperature range is from -50 to +500 degrees C. It even comes with the batteries & weighs next to nothing.
G'day mate. long time no see or hear.
Struth! -50 +500.
I hope you never see let alone feel those temps up there in the tropics.
 So, if you pay more it is good quality?
Have you actually tested an Aldi version? How did you do that?
Yes tested the Aldi version along side a fluke 64 Max and the discrepancies were Large.I returned the Aldi version for a refund. i know which one i would trust for accurate temps. last post on this from me.I have provided my opinion which is what forums are about not getting into a slanging match with a know it all.
I have a similar infrared laser temp sensor, 12:1 spot ratio, bought cheap a while ago, and it is very accurate (I compared the results with a friend's industrial laser sensor).
They are very useful when you travel to check bearing temps (and other temps).
If you are not happy with purchase you can return for refund. Win/Win.
Ignore those that immediately post negative responses from just unsubstantiated opinions.
Cheers, Richard (Dick0)
 The cheapest one I found was $8.31 looks like badge engineering with all these cheap tools.
I have been using one of these for many years:
Check tire temperature
Check Bearing temperatures
Check disc temperatures
Every stop on travels.
Fige department temps
Coffee temp etc.
Other cooking/frying temps.
And lots more.
I have checked the laser tool against thermometers of various
types, including ovens.
You only need to be a bit scientific - the beasuring circle size depends on distance
from the subject - say - in the freezer department of the frige stand back half a meter to get an average -
you will notice that a close-up reading will give localised temp, especially at the front - it will
be some degrees higher than the general reading.
But altogether, the accuracy is within ˝ deg - If you don't believe tak a reading of boiling water.
You'll get 100 guaranteed.
A very handy tool - I have written about these some years ago - actually saved me a problem with
overheating bearing on the van once in the remote parts of the NT.
B
Coffee temp etc.
And lots more. And cabin temp inside the van - and outside. Take distant readings for
general area.
They are on the web for prices from $6 to $60 (BBS Galore)
Dont bother with the dearer ones with all the features that you will never need.
B
They dont work accurately on shiny surfaces unless they have an adjustment option.
Don't forget Matilda
 Really? I don't have that problem with mine.
Clearly you dont understand emissivity. Or you just want to argue (as usual). Read this. https://www.prosenseinstruments.com.au/post/the-importance-of-emissivity-in-accurate-infrared-temperature-measurements?srsltid=AfmBOoozK6T5zr7PH2q2rwW4IdgsIYlDBeVAeNmTKCnaT8aHmrbu5UHH
msg
An Aldi
I only buy stuff that suits my needs. I am not interested in "prosenseinstruments.com.au/post/the-importance-of-emissivity-in-accurate-infrared-temperature-measurements"
 confuse
dosen't have to be accrate if you get in the habit of having a walkaround when you pull up an check wheel tyre temps you will see if some thing is out of whack then you can investigate farther before it becomes a problem usually at a inconvienent time or place ( one wheel /tire thanthan the others you soon get a feel for what theusualreading should be
-- Edited by dogbox on Tuesday 25th of August 2026 08:24:07 AM
REi b: An Aldi "Handy To Have"
I have a Matador surface temp sensor which I bought from bunnings for about $30. I haven't calibrated it but I did check a couple of temps against a thermometer and readings were identical. It's handy for checking for temperature differences after I've adjusted drum brakes (so therefore consistency is more important than accuracy).
