Post Info TOPIC: Dometic reverse cycle air conditioner roof mounted
Hi everyone, out air conditioner is rattling and shaking ?? Needs nes rubber damping /vibration kit . Is it easy to diy or does the maintenance technician need to be employed Thank you for considering
I would have thought any rubber damping would usually last the lifetime of the caravan.  It could be one of a a number of different issues. Two possibilities which I can think of would be either:
1) a problem with the compressor belt such as being loose/worn/etc
2) a problem with the fan such a as damaged blade/bearing
Maybe a caravan repairer or air-conditioning repairer might be able to help?? If the repairer isn't familiar with caravans it might be worth advising them about not just walking around on the caravan roof and potentially causing damage (eg I've used a rigid wooden board to spread the load, and kept most of my weight near the edge).
-- Edited by Rodsvan on Thursday 23rd of July 2026 03:49:51 AM
Another issue with the fan can be mud wasps. we turned ours on one day and i thought the thing was going to rip itself off the roof but it turned out that a rather large mud wasp nest had been built on top of the fan when parked up at home. cleaned it off and all good.
Thanks for input , I have booked van in for A/C service and put A/C out of commission
