Post Info TOPIC: Hitch Camera Comments
To me it is a mild inconvenience when unhitching. I need to do it every time. In my case, with an Andersen hitch, I remove the whole assembly with chains. it weighs about 15kg.
Once unhitched, pull the R clip off, remove the pin, then slide out the hitch into a bag. Then lug it to its storage spot behind the driver's seat. Hardly a chore, just an extra small step and a bit of a grunt manipulating that 15kg into its spot. A standard hitch would be negligible effort or time. Less of a chore than removing and replacing the mirrors.
-- Edited by Are We Lost on Tuesday 16th of June 2026 01:58:00 PM
Dick0 wrote:
Maybe a boat or trailer but not a van when you are travelling camping. It is a struggle to remove the hitch, rather longer than you indicate and it is more than a bit of "inconvenience". Comments by Dougwe would relate to the majority of CARAVAN towing Grey Nomads.
 What are you on about?
When I tow a boat, we are on the road for 6 months, or more.
You are not unique, but your lack of consideration for others does set you apart. Sad.
 Take a chill pill!
Cheers, Richard (Dick0)
"You are not unique, but your lack of consideration for others does set you apart. Sad."
Well, when others have some consideration for me, maybe I'll reciprocate.
"When all is said and done, more is said than done"
Simeon Craik.
