Post Info TOPIC: Tyre pressure
Tyre pressure
What tyre pressure for tandem caravan with 14 tyres
I'd respectfully suggest giving Albo a call. He seems to know all about tyre pressure.
Cheers.
P.S. That's a lot of tyres for a tandem!
Status: Online
I run my 14" LT tyres at 36psi so about 40psi when warm. ATM 2600kg.
Cheers, Richard (Dick0)
To answer your question, you need to specify the complete tyre data, the suspension type and the actual weight of the van.
Without that information, any answer will be just a guess.
Thanks for replying Ill go with 36psi
