Post Info TOPIC: Snowy Hydro 2.0
RE: Snowy Hydro 2.0
I don't understand why it is ok to divert more water from the Murray River when farmers are having water rights taken from their food growing businesses.
Solar and wind wont make additional water.
Neil
What blows the rain clouds around Neilbiggrin!!!
"When all is said and done, more is said than done"
Simeon Craik.
Neil
 "If" it happens, the water will be recirculated so no loss to river flows.
Neil
Elaborating on above.
No wind or solar water goes down hill, then goes up hill with wind or solar.
Being able to push water back up hill provides more options for water usage, otherwise than letting it run downstream when it might not be needed at that time.
One (small) matter I didn't include in my summary of Snowy 2.0's its capacity. Snowy Hydro claim that it can deliver 2000 MW for a week, or something like that. Whatever it can deliver,that is WAY above a battery installation which typically can deliver hundreds of MW, and only then for periods of maybe 1 hour. That would normally be enough to get a gas turbine started up to make up the lost generation which caused the hiccup in the first place. BUT - the batteries will only last maybe 20 years, whereas Snowy 2.0 and other Hydro equipment typically last at least 70 years. Snowy 2.0 is an investment for the future - a long-term investment at that.
Snowy 2.0 will not release any more water to the Murrumbidgee and Murray river systems - most of the snowmelt is currently being effectively used (some water gets dumped down the Snowy River, rendering it useless for irrigation further west). Pumped Storage schemes drop the water through the turbines at peak load times, and then pump the water back up the hill at off-peak times. Being able to control the pumping loads, if there is a major outage of a transmission line or a generator, the operators can open the circuit breakers to the pumps, resulting in an immediate availability of hundreds of MW being available to the grid. This reduces the need to have extra generation,available to serve as backup, should a major generator or transmission line fail in service.
In Wales (UK), there is a pumped storage scheme called Dinorwig. It is a pure pumped storage scheme - there is no inflow to the upper reservoir other than what is pumped up to it. The scheme is 1500 MW total, and it can on-load 1150 MW in 10 seconds, if there is a major disruption to the electicity supply grid. To ensure stability of the grid, it is usual to have a machine running on standby - not putting any power into the grid, but being synchronised and spinning at speed-no-load, ready to take up a load instantly, if and when a major generator or transmission line develops a fault. Basically, if the largest generator on the grid is 500 MW, you need 500 MW to be available to cover the loss of the machine. I was told by the operators at Dinorwig that the scheme paid for itself, even if it never had to make up for a lost generator. Simply being available meant that standby (thermal) generation was not required., Snowy 2.0 will provide this cover.  Snowy 2.0 will be a major asset to the country's electricity grid. Yes - it is expensive, yes - the project has been mis-managed, but it will be a major factor in future generation stability. The original $2 Billion estimate was given by Malcolm Turnbull. No doubt he was relying on information from someone else - he is not that brilliant, but he should have checked his facts before spouting off. This $2 Billion figure forms the basis of ridicule now. A figure of $6 Billion would have been a more realistic figure, and even that would be  blown out by a factor of 5 now.
-- Edited by erad on Friday 1st of May 2026 10:20:21 PM
All this furious searching of Google and hysterically copying and pasting anything he can find to try and sound informative, it seems poor old Ineedabiggaboat has shot himself in the foot again.
His bald statement that the Snowy 2.0 project has blown out to 42 billion is just another example. I see that the two people who made this statement in the media have admitted that no cost analysis had been done by them and that they were just expressing an opinion not based on any factual evidence, just their own unqualified view.
Strewth! Don't let facts spoil a good rant by the forum's prime example of the Dunning Kruger effect.
It seems that the Government have not released any projected costs and will not be doing so until all assessments have been carried out over the next few months.
They walk amongst us.
msg
Yeah you do.
DMaxer stop the insults and contribute factually not emotionally. From Leif van Onselen. The former Turnbull Coalition government initially announced that the Snowy Hydro 2.0 pumped-hydro scheme would cost $2 billion and be completed by 2021. The government increased the cost to $6 billion, then to $12 billion by 2023. The government-owned Snowy Hydro confirmed in October 2025 that the projects costs would easily exceed its $12 billion budget. A nine-month cost study by independent building experts was initiated to determine the extent of cost overruns and delays. The Victoria Energy Policy Centres director, Bruce Mountain, and energy executive Ted Woodley estimate that the Snowy 2.0 pumped hydro project will now cost about $42 billion in total. This includes direct construction costs of $20 billion, transmission infrastructure costs totalling $12 billion and interest charges of $8 billion over 15 years. Snowy Hydro cost blowout Mountain and Woodley say Snowy 2.0 had always been a dreadful idea and labelled it one of the biggest disasters in Australian infrastructure. They agree that a royal commission into the project may be justified. Successive governments have failed to respond to a project that was so obviously doomed right from the start, said Dr Mountain. Whats always been needed here is properly independent investigation, he said. I think there is a case for a Royal Commission into this. Mountain noted that Snowy Hydro 2.0 now employs 50% or roughly 3,000 more workers than originally budgeted, averaging $250,000 annually, with powerful unions including the CFMEU and ETU participating. Snowy 2.0 is, and always was, a dreadful idea, he said, citing its price, environmental damage and a storage system that cannot be quickly recharged like batteries. Concerns have also been raised that the federal government has sought to conceal the true cost of Snowy 2.0 by using off-budget vehicles and blocking freedom-of-information requests. Former ACTU President and federal Labor MP Jennie George also criticised the way in which the true cost of the renewable energy transition has been deliberately hidden from public scrutiny through off-budget accounting and separation of interconnected costs. The NDIS, at least you know the cost of it, because thats public in all the Budget papers. Whereas a lot of this is hidden, you just wouldnt know, George said. For a government committed to accountability and transparency, theres no defence for keeping from the public particularly from the taxpayer who underwrites a lot of these projects just what its actually costing us. Vested interests wouldnt be pursuing projects unless they had the certainty of being underwritten by government, she said. The estimated cost of the 2,000-megawatt QLD Borumba Pumped Hydro project has also increased by $4.2 billion to $18.4 billion, with completion not expected until 2033 at the earliest. As with Snow Hydro 2.0, costs are certain to rise. Snowy Hydro 2.0 and Borumba are only microcosms of the astronomical costs of the renewable revolution. Pumped hydroelectric projects create no net power. They serve as storage vehicles for excess renewable energy (mostly solar) generated in the middle of the day. Battery storage and a distributed network of solar and wind turbines with transmission lines scattered throughout the countryside are also very costly. Weather-dependent energy is intermittent by nature. As a result, it is prohibitively expensive due to the extensive infrastructure, transmission, and storage requirements, as well as the need to keep dispatchable hydrocarbon generators on standby in case wind and solar power fail. Australian customers, therefore, face increasing energy costs, both directly on their bills and indirectly through taxes to fund renewable energy subsidies and projects like Snowy Hydro 2.0. Policymakers should stop gaslighting and be transparent about the costs and trade-offs of Australias renewable energy transition.
Don't forget Matilda
I asked AI to make the post readable.
DMaxer, stop the insults and contribute factually, not emotionally.
From Leif van Onselen: The former Turnbull Coalition government initially announced that the Snowy Hydro 2.0 pumped-hydro scheme would cost $2 billion and be completed by 2021. The government later increased the cost estimate to $6 billion, then to $12 billion by 2023. In October 2025, the government-owned Snowy Hydro confirmed that the projects costs would easily exceed its $12 billion budget. A nine-month cost study by independent building experts was initiated to determine the full extent of cost overruns and delays.
The Victoria Energy Policy Centres director, Bruce Mountain, and energy executive Ted Woodley estimate that the Snowy 2.0 project will now cost about $42 billion in total. This includes direct construction costs of $20 billion, transmission infrastructure costs totalling $12 billion, and interest charges of $8 billion over 15 years.
Mountain and Woodley argue that Snowy 2.0 had always been a dreadful idea, describing it as one of the biggest disasters in Australian infrastructure. They suggest that a royal commission into the project may be justified. According to Dr Mountain, successive governments failed to respond to what he sees as a project that was obviously flawed from the beginning. He argues that a properly independent investigation has always been needed and believes there is a strong case for a royal commission.
Mountain also noted that Snowy Hydro 2.0 now employs about 50% more workers than originally budgetedroughly 3,000 additional staffearning an average of $250,000 annually, with powerful unions including the CFMEU and ETU involved. He criticised the projects high cost, environmental impact, and limitations as a storage system that cannot be quickly recharged like batteries.
Concerns have also been raised that the federal government has attempted to conceal the true cost of Snowy 2.0 by using off-budget vehicles and blocking freedom-of-information requests. Former ACTU President and federal Labor MP Jennie George similarly criticised the lack of transparency, arguing that the true cost of the renewable energy transition has been deliberately obscured through accounting practices and the separation of interconnected costs.
George contrasted this with the NDIS, where costs are clearly outlined in budget papers. She argued that much of the spending on renewable projects is hidden from public view, despite taxpayers underwriting many of these initiatives. She added that governments committed to accountability and transparency should fully disclose the actual costs involved, and suggested that vested interests would not pursue such projects without the certainty of government backing.
The estimated cost of the 2,000-megawatt Queensland Borumba Pumped Hydro project has also risen by $4.2 billion to $18.4 billion, with completion now not expected until at least 2033. As with Snowy Hydro 2.0, costs are likely to continue rising.
More broadly, Snowy Hydro 2.0 and Borumba are presented as examples of the wider costs associated with the renewable energy transition. Pumped hydroelectric projects do not generate net new energy but instead act as storage systems for excess renewable energymainly solarproduced during the day. Battery storage, along with distributed solar and wind generation and expanded transmission networks, also involves significant expense.
Because renewable energy sources are weather-dependent and intermittent, additional infrastructure, storage, and backup generation are required. This includes maintaining dispatchable hydrocarbon-based generators to ensure reliability when wind and solar output falls.
As a result, Australian consumers face rising energy costs, both directly through higher power bills and indirectly through taxes that fund renewable energy subsidies and major infrastructure projects like Snowy Hydro 2.0. The argument concludes that policymakers should be more transparent about the true costs and trade-offs involved in Australias renewable energy transition.
Not sure what changed.
Until you are, your posts will remain unreadable.
Ineeda.jpgJust in case whatever device you use shows it as normal, here is what I see.
I am guessing you wrote it on your device then copy pasted it to the forum. If so the punctuation for new line or paragraph used by your device or editor is apparently not recognised by this forum.
-- Edited by Are We Lost on Saturday 2nd of May 2026 01:34:50 PM
Im using iPhone 17 iOS Beta 26.5 My display looks absolutely normal, proper paragraphs, widths etc, nothing like yours.
Nevertheless *CLEARLY* the Apple product is stuffed - all your longer posts make this very clear or rather most unclear.
Just toss out the Apple software and get a basic text editor - even Apple must be able to provide one of those.
Nah, just wont post long stuff.
Silenced by optional conformity to the rules.
Not the first... and won't be the last....
The issue is how Apple handles rich text formats. There are ways around it but to be honest, its not worth posting with obnoxious people like DMaxer just try and ridicule people. Im done.
