Post Info TOPIC: Starlink Gen 3
Starlink Gen 3
I recently got starlink gen 3 equipment, I have noticed that the face of the router is very hot, is this the normal
I wouldn't say 'very' hot but it is warm all the time. The power supply is also the same. I got a wall mount from evilbay that holds both with airflow so all good.
 Thanks for the suggestion/advice a great idea, I may even look into 12 v  Power supply as well
Is 'snow melt" on ?
How do I adjust snow melt mode?
To adjust Snow Melt setting, open the Starlink app > Navigate to Settings > Starlink > Snow Melt > Select the preferred mode:
* Off: Never melt snow
* Automatic: Automatically detect snow and heat Starlink terminal when needed.
* Pre-heat: Keep Starlink terminal warm to better resist snow build-up. This option may increase power consumption
Good information Ken.
I have changed my snow melt mode from Auto to Off, the temp on the router has dropped from being hot to just warm. I have also noticed the power consumption high spike of high sixty watt mid forties, the average is now 39w.
I don't have Starlink gear, but my understanding is that the power for the dish is generated by the external PSU and merely passes through the router and on to the dish via the Ethernet cable (PoE). The router should only consume an amount of power sufficient for its own operation, and that would be relatively minor. The dish and power supply do the "de-icing", not the router. Therefore, I don't understand why "snow melt mode" would have any noticeable effect on the router.
-- Edited by dorian on Tuesday 21st of October 2025 06:40:31 AM
