Post Info TOPIC: Cartopper tinnys
Cartopper tinnys
Hi Boaties, wanting recommendations on which tinnie to choose Sea jay 3.5h/s or quintrex F350 outback. Thanks
Mark Naidoo
Check the legal limit of the pack rack and loaded weight of the tug first.
The chances of being legal AND safe are pretty low.
Have a look a Porta-bote. Folds up, goes on the roof rack.
Don't forget Matilda
Hi Justpokinlong
I have a Quintrex Wanderer 320 with a 4.5 Yami motor. Both units a light and easy to load and unload and comfortable for two. Great for the rivers and dams, bit on the small side for Crock rivers.
A Rhino side loader fitted onto the canopy of the DMax and a Folda Trailer carried in the canopy, hook up the van and away I go.
Never get so busy making a living
that you forget to make a life
If you are towing a van and want a rooftop tinnie, chances of you being within legal weight are very slim. As Peter says, well worth checking (with actual weighing, not just approximation). Last year Qld Police reported over 90% of vehicles they tested (in voluntary weigh stations) towing with a rooftop tinnie were overweight. A recent YouTube video by a mobile weighing company said 100% of the vehicles they checked were overweight!
Yikes!
cheers,
Mark
  Mark
Im a boatie, have owned several larger ones. I would love to be able to take a boat with me, but wouldnt be legal. I shake my head at some of the setups I see on my travels.
Anyhow, a couple of years ago down around the Ayer peninsula, I saw several of those port-a-boats and I was more than impressed.
Obviously depends on what usage you have in mind, but in my opinion well worth a look.
I went a different direction and purchased a double kayak, for its size and use 90% of the time on my own. Have used it in lakes, dams, rivers and oceans..
shakey55
Want to take a boat on your travels?
Get an appropriate motorhome.
We took these to the Kimberley from Adelaide.
If you intend to go into croc country or areas with strong tides, choose your boat very carefully.
I had a Porta-Bote for quite a few years, took it many places (Kimberley, Tasmania, Cape York, etc.). I did use it in some waters where crocs were present, but not in places like Corroboree Billabong, where crocs have been known to harrass smaller boats. It was an excellent addition to our travels, though the low freeboard did limit conditions you could use it in. You still had a bit of gear to carry- seats and transom, engine, safety and fishing gear, but it was a very feasible option weightwise.
As for towing a boat with a motorhome, we did that around NZ South Island and I personally found it to be a PITA... Having to drag the van out every time we wanted to launch the boat. Each to their own, of course. There's no best option, just your best.
We found (for us) an excellent option towing our 6m boat around, mostly, WA last year, using our lift off canopy to set up camp while we could still allowing us to launch the boat.
I'd love to take a tinny and decent outboard, but the compromises (Much larger vehicle, which I dislike for touring, greater cost etc) put me off.
Mark
  Mark
We have a 3.6M X 1680mm wide Blue Fin HD custom built with 18hp Tohatsu outboard.
Two people can stand on one side with out any problems as its very stable.
The wife and myself are keen fishing people and have lived on the road full time since 2006
Originally had it setup on a 105/4.2 /TUrbo/Auto cruiser with 3300kg fully loaded Off-road caravan and
Still within legal limits.
Darjak
darjak
How have you progressed with the tinny?
Regards Ian
