Post Info TOPIC: Wagga to Tathra
Wagga to Tathra
I intend towing my 3.3t van with our 2001 4.2td patrol from Wagga Wagga to Tathra in late February.
Was wondering the easiest route, thanks, Geoff
2005 GU 3.0L TD Nissan Patrol, Cameron Canvas Offroad Camper Trailer.
I would not be going via the Clyde Mtn and Batemans Bay. It's an hour and 100 km longer than going down Brown Mountain. The gradients are around the same on both descents. You can check them out here:
For Brown Mtn see Map of Snowy Mountains Highway, NSW
For Clyde Mtn see Map of Kings Highway
I have no preference for either road, I just take the most convenient one for each trip. I suggest you should take a positive attitude to driving these types of terrain, if you don't, you are going to miss out on a lot of good trips. When you have gained your confidence on this route you will enjoy trips across half a dozen routes across the Great Divide in both NSW and Qld plus a couple in Vic. Just use your gears to make it easy to climb the ascents and to provide engine breaking on the descents. If you slow down and shift into a low enough gear so you don't have to spend too much time on your brakes when descending, you will have good working brakes after you have descended each hill you go down.
If you're towing a 3.3 Ton van do not attempt to go down Browns Mountain.  Take the Kings Highway.
I towed our 2.5 ton van down Browns behind a DMax using gears as I have done for 20 years, no way would it hold, it's not a place for a lesson in mountain decent. Avoid it for your own safety, there are better ways to go!
Chris & Sharyn.
Tea Gardens. NSW.
I guess it depends upon your level of experience/comfort in towing on hills. I have towed our various caravans up and down the Brown Mountain, Clyde Mountain, Macquarie Pass, and all through the Snowy Mountains (where permitted) on numerous occasions. I used to sometimes drive semi-trailers for a living on these same roads.
I'd still recommend the Brown Mountain road over the Kings Hwy/Clyde Mountain route.
Another way is down Mt Darragh. Quite a bit longer to travel to Tathra but the descent is not as long nor steeper.
Drive to Bombala, at the town cross the river and turn left at the roundabout. Follow that road all the way down to the Princes Hwy. While the road is narrower than the Brown as mentioned it is not as long, steep nor winding. At the bottom there is a single lane bridge over a creek that need to be approached with care for oncoming traffic.
(On the way down to Bombala there is a finger sign pointing to Pambula but it is a dirt road and local knowledge was that it was in poor condition. So we opted for sealed roads all the way and ignored it.)
Once on the Princes Hwy turn left and head north to Pambula, Merrimbula or Bega from those towns it is an easy drive to Tathra.
Its called Brown Mountain for a reason. I wouldnt tow my van down there again. It is a 10 kilometre step descent. It was not so much the descent but the idiot in front of and behind me.
We use the Brown Mountain road approx every 3 weeks in the car and I've driven it dozens of times towing our caravan. It's just a matter of using your gears manually (including with automatic cars), knowing how to brake properly on long descents and having the brake controller set properly. We followed a caravan down there on Monday and the driver clearly did not know this. They were creeping along and riding their brakes the whole way and their brakes were overheating badly.
msg
I have done Brown Mountain, Kings Highway (Clyde) and Macquarie Pass many times. I would pick Kings Highway. But I drive a 6 speed shift 3.5ton motorhome and do not know what's involved in towing.
