Post Info TOPIC: Can’t light Swift 500 series oven
Tried to light the oven , have gas and a piezo spark ??
RE:
Hi Jarrah, does your grill top light o.k.? Could be worn piezo, grill top lid has a safety switch when you open the grill lid, this allows the gas to pass thru. If you have a 3 way fridge does it work on gas? Could be a faulty or partly clogged gas regulator at the bottle.
J. Price
RE: Can’t light Swift 500 series oven
Here is a copy of the Swift 500 Service manual.
May not help with your particular problem but may be useful.
Status: Online
Our SMEV requires the gas to be held ON manually for quite a long time to light the oven. Much longer than the hob burners.
To ignite our oven, we have to open the cover over the hot plates. When closed, the cover has a cut-off device for gas to the stove unit.
As Peter has stated, often it takes longer for gas to reach the oven. We make sure gas is at the stove by igniting a hot plate first, then we know that gas has reached the stove at least. Then it can take a bit longer for the oven to ignite.
Status: Online
And the piezo may click, but not light the gas. Try a manual lighter at the same time.
RE: Swift 500 oven
Thanks for all suggestions
RE: gas oven Swift won’t light
The gas fitter is coming to check it out . Ill let you know what he says
RE: gas oven won’t light
So . The gas pipe into the oven had worked itself loose the fitting was lying free .. definitely needed a visit from the gas fitter .
Here is a pic of the oven and the fitting that had worked loose , purple arrows
