Post Info TOPIC: Tow ball nut
Tow ball nut
What size socket are people using for the towball nut. Hayman Reece says 32.5 mm. Cant buy such a thing so wondering what to get. Dont/can't use a shifter on my tongue
-- Edited by jade007 on Sunday 13th of April 2025 02:07:15 PM
33mm does the job nicely. Available from Sydney tools. There is an Imperial equivalent which is probably the true size but I cannot remember what it is, however I have the 33mm deep impact socket and that works a treat.
Greg O'Brien
Thanks Greg 1
www.bcf.com.au/p/hayman-reese-multi-fit-tow-ball-spanner/376686.html
try here for a start or a pipe wrench will do in a pinch
I use one like this, simples.
Cheers, Richard (Dick0)
The multi fit spanner will not work on my towball tongue. No room. Mitso genuine towbar. Cheaper to buy a socket than replace the the tongue
-- Edited by jade007 on Monday 14th of April 2025 03:55:25 PM
Socket and a rattle gun. Found the towball spanners not that good. You can also use a long knuckle bar with a socket. Shifters and pipe wrenches should always be the tools of last resort. First thing I was taught as an apprentice mechanic. Tool priority list. Sockets Ring spanners Open end spanners Shifters Hammer and cold chisel. Gas axe.
Greg O'Brien
Status: Online
An auto standard 50mm ball has an M22 shank. An M22 nut is 32mm across the flats.
Sounds like some of you are using imperial stuff?
IMG_4378.jpegIMG_4379.jpegI use this, either with rattle gun (preferred method) or a breaker bar.
Thank You all
And somewhere near 250 nm of torque so should be pulled up with a 3/4 drive socket and a meter or so of leverage
 How many ugger duggs is that. ;)
Peter and Margret. None of the 50mm balls I have in my possession have a 32 mm nut across the flats. They all are 33mm. I tried both 32mm sockets and open end spanners and definitely too small. Measured with a vernier it is just a smidge under 33mm and a 33mm socket is perfect fit. Tried my mates tow ball same story.
Greg O'Brien
 Yes I have a 32mm and it will not fit hence the question in the first place
My practice it to use a large shifter and pull until the split lock washer is fully compressed and then pull a smidgeon more until a crack is heard from the elbow - that equals about 250 nm.  biggrin
I'd use my torque wrench if I had a suitable socket. The ball actually stays on its tongue and I swap tongues so don't have to remove and refit the Ball or DO-35 hitch.
Status: Online
 Then they are 3/4" UNF, not M22.
 Yes, M22 is far too small.
Agree totally with Peter .
The imperial nuts are 1 1/4 inch AF, which equates to 32.999 mm.
Alan
