Post Info TOPIC: Silicone Odour
Silicone Odour
Hello my name is Vicsta and this is my first post. I was wondering if anyone could help me with a problem with our new caravan. We love our new Urban caravan but it has a really strong smell of silicone inside the van. I slept in it for 1 night and woke up the next morning with a bad headache and I felt quite unwell for a few days. Does anyone have any ideas on how I can get rid of this smell. Our van is in storage so we cant leave the windows open while its in there, I have tried odor genie which was useless. looking forward to any suggestions
homeycons.com/how-to-get-rid-of-silicone-sealant-smell/
Silicones are banned in our vehicle.
-- Edited by Peter_n_Margaret on Friday 31st of January 2025 06:17:11 PM
Usually get the strong smell when acetic cure silicone is used. Most people have gone away from that product and use a neutral cure which is relatively odour free. Unfortunately the only way to get rid of the odour is to ventilate the van. It will eventually disappear but it does take awhile until all the acetic acid evaporates out of the silicone.
Greg O'Brien
Acetic cure generally has superior physical properties.
No not true. I spent a lot of time testing various silicones and polyurethanes in my secular work. Some of the really high grade silicones used for things like curtainwall glazing are all neutral cure. For example Dow Corning 795 is a high modulus structural silicone often used for that purpose. That comes as a cartridge type single pack silicone. But if you have the right equipment you can get very high grade structural two pack silicone also neutral cure but the equipment to apply it is $100,000 + and the silicone comes in 44 gallon drums. The neutral cure is because acetic acid often reacts with various substrates to their detriment and also the interlayer in laminated glass. In high rise curtainwalling, the modules are completed in a factory in a controlled environment and every 10th panel is tested to destruction. That ensures the silicone has adhered correctly. When selecting silicones, read the label. If you are using it as an adhesive as well as a sealant then choose one that states high modulus regardless whether it be acetic or neutral cure. You need to know if the substrate you are using it on is impervious to acetic acid or not if using acetic cure. If unsure choose a neutral cure. I very rarely ever use acetic cure these days.
Greg O'Brien
Welcome to the Forum Vicsta.
Unfortunately there is no magic bullet to kill the acetic acid fumes generated by the curing - take heart it will dissipate in time.
