Post Info TOPIC: Iveco 50C18 Daily Diff Pinion Seal
Hi Travellers Has any one had experience in changing a rear diff pinion seal on an Iveco, the quote from Iveco, was to say the very less " A faction Under the Bloody Nation Debt" .
I have managed to procure a seal, Genuine Part
Any Advice  would be greatly appreciated,
Safe travels
Cant be much different to this.
www.youtube.com/watch
https://www.youtube.com/watch?v=0Gpl6D76vzc
-- Edited by rgren2 on Monday 16th of December 2024 09:13:31 AM
So what was the quote?
If you are not competent to change it yourself, you will need to pay someone else to do it for you. Any competent mechanic can do it.
I,ve done a few in the past, the yoke nut has a very high torque to start with, some diffs have a collapsible spacer to set the pinion preload, you need a special tool that measures the force to rotate the yoke, this sets the pinion to crown wheel engagement, take it to a diff specialist, diffs are expensive to replace or rebuild.
J. Price
Thanks for the reply's
Iveco quoted Labour only $677
Have found a Mech specialising in Iveco's who can do it for $150 about 1 1/2 hours work
 Looks like the Mech specialist is going to get a job. Good luck with the diff.
As for the quote from Iveco, and people wonder about the causes of inflation.
All sorted $163.00
