Post Info TOPIC: AL-KO Wheel nuts
AL-KO Wheel nuts
Can anyone tell me the size off wheel nuts for AL-KO 10 six stud Landcrusier electric brake drums
Just take one into any auto store, theyll size it for you.
AL-KO 10 hub drum 6 x 139.7mm PCD (6 stud Landcruiser) with 1/2 UNF studs.
All of AL-KOs hubs are manufactured from high grade ductile iron to give maximum achievable strength.
Maximum axle capacity 1450Kg
To suit electric backing plate 10 x 2 1/4
D : 254mm
W : 54mm
Studs : 1/2 UNF
PCD : 6 x 139.7mm (6 x 5 1/2)
S : 69.85mm
Compatible bearings : LM (holden), Slimline (Ford), Composite (Holden inner, Ford outer)
Studs can easily be replaced, dont always rely on spec sheets.
Great thanks guys for your input
 What a stupid system.
Nothing on a Landcruiser is imperial. It is metric.
If I owned a Landcruiser tug, I would want the rims, tyres, studs and nuts to all be metric and identical to the Landcruiser so that everything was interchangeable.
