Post Info TOPIC: Caravan Water Filter System
I'm sure many of you have fitted water filtration systems to your caravan.  I live in my caravan and I am looking for an ECONOMICAL water filtration system.  Please tell me about your system, or the system you would recommend.
Welcome to Forum Peet - I wouldn't bother with filtration system personally (raised on tank and bore water).
You could always purchase a water jug that has a small carbon filter cartridge in the base.
I suppose if you buy a water filtration for a home you would need mains water pressure to operate it? Maybe the undersink pump could do it. Like the op said on counter filtration jug sounds better
We use a 10" twin filter system in the OKA that is after the RV pump and before the taps.
The first cartridge is a 5um sediment filter just to keep most of the muck from the second cartridge which is a 0.5um carbon block filter.
The RV pump is quite adequate to operate it with plenty of flow.
The whole thing costs less than $100 and a pair of replacement filters costs under $40 about once a year.
Which brand do you use Peter.
I've looked into this before, but the cost of the cartridges seem extraordinary. But given the odd places we fill our tanks from, I think a water filter on the drinking water tap would be a good idea.
I tend to purchase according to the specification, not the brand.
Good quality carbon block filters can cost upwards from $35 each. That is the important one. I have purchased the sediment filters at under $5 each.
The attraction to these filters is that the replacement cartridges are readily available, even from Bunnings.
www.bunnings.com.au/stefani-0-5-micron-ultra-fine-universal-replacement-cartridge-250mm_p5090024
It is also important that the water in your tanks is chlorinated. If it is not chlorinated town water when we fill, we add extra chlorine.
ps... Purtec is a well respected brand, but tends to be expensive.
-- Edited by Peter_n_Margaret on Monday 9th of September 2024 09:13:14 AM
Excessively mineralised water is not ideal for people with some health issues. Especially kidneys.
Our home water filter has a pressure reducing valve.
 Yesterday I purchased some replacement cartridges from Freshwater Systems Australia in Adelaide.
10 x 5um sediment filters @ about $3.50 each.
5 x 0.5um active carbon block @ about $20 each.
I fitted a filter unit at the caravan kitchen sink both in my previous pop-top and current van. Bought the units from Bunnings. Bought the 0.5 micron cartridges on Ebay.
Cheers, Richard (Dick0)
