Post Info TOPIC: Mattress topper recommendations
Chasing a mattress topper, preferably fitted.
What do others use?
Thanks
2021 Goldfields Grand Duke Forward fold hardtop camper trailer
We have single beds with fitted lambs-wool slip on covers.
Whatever you use at home.
We are getting older, look at a waterproof one.
Welcome to the gang jpd1009, enjoy here and out in the playground.
I used to use yellow 'egg cartons' from Clark Rubber. I say "used to" because I was told I was hot in bed. So had to stop using due to sweating too much.
What did you think I meant when I said I was hot in bed biggrin
I now just use a pure wool underlay and cotton sheets and doona cover. All that has made a big improvement.
We use a memory foam topper, ours is a Tontine one bought from Spotlight. Made our too hard bed super comfortable. Have tried an egg shell one and it was nowhere near as comfortable. Memory foam is also easy to cut to exact size with an electric or very sharp knife to round corners etc if needed.
You can also get Memory Foam in the Egg Crate form, I have a mattress with a memory foam topper built in so if I were adding one for comfort I would get memory foam in either design.
You could just get either style of just foam and use a mattress protector to hold it in place/make it easier to make the bed because of the foam grabbing onto any blankets or sheets without a cover on it.
Kebbin
We had a brand new, high quality mattress specially designed for our caravan and also added a sturdy mattress topper.  Outcome was that our caravan bed is still very uncomfortable  and we have learned to live with it ( and my back pain every time I sleep on the caravan bed intensifies).   I believe it is because of the ridiculous slats that pretend to be a mattress base which in our case are as good as useless.  Has anyone modified (removed) these useless slats and replaced them with something more sturdy?
Nissan Patrol TIL and highly modified Retreat Fraser full offroad version
We have a 'Hilton' 75mm memory foam topper from Pillowtalk. So good we bought another for our bed at home !. Not cheap but worth every cent. We both have pretty severe arthritis and this topper takes all the pressure off your bones and aching bits. Unreal !!
Same as at home , Super Sleeper Pro .
Jontee.
Remember, the price of liberty is eternal vigilance.
