Post Info TOPIC: AvidaLongreach Winebago
I am looking for info on what and how is the piping under the floor of a shower base in an avida hooked up as i have a small leak. Has anyone pulled a shower unit out.
GB
We have 2008 Longreach. Check the silicone around thr base in the shower for any loose filer, especially below the shower door. Also in ours the pantry is next to the shower and base of pantry lifts out after removing screws. Last check is tap and shower fittings are tight. Need to find what is actually leaking before pulling apart.
Roger
Yeh thanks Roger, just about to check fittings before i go into that for sure, my fridge is next to it but will check if the wall comes out in this draw. All the bottom of the glass i just did and it did slow it so im hoping only fitting now. Thanks for suggestions open for more if anyone else has the same issue not sure it the two plugs go into one.
GB
Ive sealed all areas possible, i tried removing the water spout from the wall where the hose connects to, and it just turns. Has anyone taken these out before?
GB
All sorted now leaking through tap that the last bloke played around with, no more leaks and no cutting thank god
GB
