Post Info TOPIC: Need more help with Centurion power converter.
Hi, I have a Jayco Westport 2001 with the above power converter fitted and it blew a fuse recently, I want to obtain a manual to see if I can find out why. According to the colour coding it was a 20amp fuse but I have no idea what that circuit that is part of. Any help would be appreciated.
Hi again, I am at a frustrated point in my relationship with my caravan, battery and converter. It now seems that the converter, which fused, also cooked my 120Ah AGM battery. As a temporary measure I need to bypass the converter and battery to run on caravan park 240v; anyone know how to do this, please?
Edwin Daly
The Centurion will run on 240V only. Disconnect your battery from the +ve and -ve terminals on the centurion connection strip. Connect your 240 lead to van, You should then have power to all your 12V loads. Check the 12v fuses if something is not working.
You will then need to buy a battery charger, connect it to the battery and plug into a 240 power point in the van, leave on when you're using the van, turn on regularly at home to maintain battery condition.
Chris & Sharyn.
Tea Gardens. NSW.
Welcome to the Forum Teddy, will leave the power question to those more qualified.
